Router Misalignment? - Page 3 - Router Forums
 21Likes
post #21 of 26 (permalink) Old 03-31-2020, 06:21 PM Thread Starter
First Name: Cole
Default Channel Completed ,,,YES!!
Well folks, the sled-jig worked, not 100% But way more satisfactory than the previous attempt.
Thank you.
20cCc20 is offline
post #22 of 26 (permalink) Old 03-31-2020, 06:22 PM Thread Starter
First Name: Cole
Not a bad router,,
Kind of looks like a ,,,cycloptic Shrek!
TenGees likes this.
20cCc20 is offline
post #23 of 26 (permalink) Old 03-31-2020, 11:49 PM
Originally Posted by 20cCc20 View Post
Not a bad router,,
Like my M12V2. The looks turned a lot of prospective buyers off which was too bad because it is a top notch router for both handheld and router table use. I was told quite a few years ago that one of the older members of this forum left because he got tired of being kidded about it.
post #24 of 26 (permalink) Old 03-31-2020, 11:56 PM
@20cCc20 ...
where dies this pat get installed???
is it an apron???
post #25 of 26 (permalink) Old 04-01-2020, 06:26 AM
TenGees's Avatar
First Name: Paul
Cole, I had depth problems with my first attempt at a home-made router table. I had used 1/4 inch cast acrylic (plexi) for the plate. It seemed stiff but it sagged. When holding the material down the ends would get a deeper cut than the center. Very noticeable on smaller round-overs. I have an aluminum plate now - big difference.
Glad to see that you're getting better results.
TenGees is offline
post #26 of 26 (permalink) Old 04-06-2020, 12:12 PM Thread Starter
First Name: Cole
The biggest mistake I made was, the minimal clamp down with the first jig with the assumption that I would make each cut in one pass.
The plunge feature allowed me to resume my cuts precisely after I alternated my clamps on the stock from end to end. This was much safer and surprisingly accurate. It took a bit longer than doing the cut in a single pass but the extra safety precaution paid off as you can see. Safety should always be paramount when using any powertool, everything just falls into place afterwards.
Cheers!!!
TenGees likes this.
20cCc20 is offline
