Methods To Make This Cheese Cutting Board? - Router Forums
 11Likes
post #1 of 13 (permalink) Old 03-29-2020, 04:53 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Methods To Make This Cheese Cutting Board?
Hi all,
What would be the possible methods and cutters to use to make a cheese board like in attached? I have a Record Power cast iron router table with a sliding table is fitted with a Dewalt 625 1/2" router, as in attached. I also have another 1/2" router about the same spec and a much smaller one about 1100 watts I think it is. Timber size, 255 long 190 wideand 15mm deep.
Gaia is offline
post #2 of 13 (permalink) Old 03-29-2020, 06:45 PM
difalkner's Avatar
First Name: David
That's going to be easier with a plunge router than a router table.
David
Edit - a quick search and there are dozens of videos on this, so here's one below
MEBCWD, swarfmaker and sreilly like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 13 (permalink) Old 03-29-2020, 06:45 PM
kp91's Avatar
First Name: Doug
Try looking at bowl and tray bits.
Then it is a matter of using a template to define the boundaries of the recesses
JFPNCM, MEBCWD and sreilly like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 13 (permalink) Old 03-30-2020, 08:52 AM Thread Starter
Gaia's Avatar
First Name: Peter
" That's going to be easier with a plunge router than a router table. " Thats what was thinking too. Which YouTube search term did you use?
Cheers.
" Try looking at bowl and tray bits. Then it is a matter of using a template to define the boundaries of the recesses "
Ok thanks, info on using templates for this or likely to find on the YouTubes?
Cheers.
Gaia is offline
post #5 of 13 (permalink) Old 03-30-2020, 09:07 AM
Bstrom's Avatar
First Name: Brian
I need to learn this too. Thanks for the info!
Common Man Woodworking
Powell, TN
Bstrom is offline
post #6 of 13 (permalink) Old 03-30-2020, 09:29 AM
difalkner's Avatar
First Name: David
Used Google, went to Videos, picked a short one for example (watched it first, too! ) - Router serving tray diy
David
Gaia likes this.
David
Romans 3:23
post #7 of 13 (permalink) Old 03-30-2020, 09:30 AM
kp91's Avatar
First Name: Doug
I would use a template guide bushing and a shop made template. I would define the outside boundary first, then use a ski or sled type of arrangement to clean the bottom.
The first bit I would use for the boundary is an uncut spiral, set in a little from the edge to hog out a bunch of the waste and make things easier on the bowl and tray bit. After that, use the bowl and tray bit to define the perimeter.
Then make a simple sled using a board that will span the platter, and use the spiral bit to hog out the majority of the waste. Put the bowl and tray back in, set it just shy of the depth you made the perimeter, and finish off the bottom. The nice thing about the bowl and tray bit is that it leaves a lot nicer finish than a straight cutter.
If I weren't stuck out here at sea I would show you my setup... hopefully I am describing it OK
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 13 (permalink) Old 03-30-2020, 09:30 AM
Danman1957's Avatar
David,
Thanks for sharing that. It's something I will try. I have slabs of Walnut that I'm sure will look good after a few practice runs.
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is online now
post #9 of 13 (permalink) Old 03-30-2020, 09:59 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thans David.
difalkner likes this.
Gaia is offline
post #10 of 13 (permalink) Old 03-30-2020, 10:22 AM Thread Starter
Gaia's Avatar
First Name: Peter
kp91,
Yes I get the gist of it. " If I weren't stuck out here at sea " Perhaps safe place to be, just at the moment.
DaninVan and difalkner like this.
Gaia is offline
