Rabbets on end of plywood help needed - Page 2 - Router Forums
 39Likes
post #11 of 26 (permalink) Old 04-23-2020, 05:57 PM Thread Starter
I did this with dado blade on the TS. Can this be done with a router and how?
PAWOODCHUCK is offline
post #12 of 26 (permalink) Old 04-23-2020, 06:03 PM Thread Starter
First I did these with the TS and Dado blade setup but took a lot of setup time only to find was too tight fit, so I used the bit sized for plywood. Any tips how center the bit when making the cut "X" inches from edge.
Still need to do face trim.
post #13 of 26 (permalink) Old 04-23-2020, 08:45 PM
CharleyL's Avatar
First Name: Charley
An exact width dado jig and your router will get the results that you need. There are several versions available, but Stumpy's is well explained. You can search for the rest and choose the version that you like best.
Charley
Central North Carolina
CharleyL is online now
post #14 of 26 (permalink) Old 04-23-2020, 09:56 PM
since we don't know what size rabbet you want...
a rabbeting bit may take care of it...
if you need a larger rabbet than those bits can give you go w/ a straight bit or a mortising bit instead... a spiral bit would be over kill...
a clamp on straight guide is just the ticket for those two bits...
unless you already have an edge guide for your router...
and read your thread for other methods...
jj777746 likes this.
post #15 of 26 (permalink) Old 04-24-2020, 12:04 AM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #16 of 26 (permalink) Old 04-24-2020, 01:23 AM
Here's a rabbeting bit and a mortising bit. Rabbets are rarely wider than the thickness of the piece you're glueing into it. The rabbiting bit has a bottom mounted bearing you let ride against the edge of the wood. You can get them with several diameter bearings and change them out. Using an edge guide and the mortising bit, you take a scrap of the material and lay it on edge where you want the rabbet. Use it to scribe a short line on each side of the piece you want to rabbet. Lay a straight edge (the factory edge on a half inch piece of MDF for example) from scribe mark to scribe mark. Your mortising bit's bearing will roll on that edge.
Plywood is not 3/4 inch thick anymore, it is not 18mm, slightly thinner. So your bit should go no deeper than about half that thickness. You can see that a 3/4 diameter mortising bit will remove the entire rabbet area just fine.
Dados and grooves are another matter. You can buy an 23/32nds plywood bit just for that purpose, but there is no guarantee that any particular piece of plywood is exactly that thickness. So for a dado or groove, you are much better off using a half inch bit as suggested and an exact width dado jig as in the video. They are pretty easy to make. Here's a drawing.
You fit a piece of the material that will go into the dado or groove between the two horizontal boards and use the star knobs to cinch tem down. Clamp the jig securely in palce and begin to do the routing. A half inch straight bit will work but I'd go right back to a half inch mortising bit for this. The top mounted bearing will ride on the side of the rails as you slide the router first one way, then the other. One important feature of mortising bits is that they cut a really flat bottom groove, rabbet or dado.
Name:	Mortising bit with bearing.jpg
Name:	rabbeting bit with bearing set.jpg
Name:	Exact Width Dado Jig - Mike.jpg
Nickp, jj777746 and dirt_dobber like this.
DesertRatTom is online now
post #17 of 26 (permalink) Old 04-24-2020, 01:23 AM
Pa; they're done now, but those rabbets and dados are too deep (in my opinion). Normally I'd only go 1/4" deep.
DesertRatTom likes this.
DaninVan is online now
post #18 of 26 (permalink) Old 04-24-2020, 05:41 AM
Nickp's Avatar
First Name: Nick
This video shows how to make a straight edge for a router guide for cutting grooves/dados/rabbets...but you must dedicate a specific bit for a specific router...
Two straight pieces of wood, small one on top of the big one...then you take your router with the dedicated bit and run it with the edge of the router against the edge of the top piece. This will then cut the bottom piece referencing the top piece. When you use it just line up the edge of the guide where you want the dado/groove and it will cut the dado/groove on that line...check out the video on how to make...
Nick
Nickp is online now
post #19 of 26 (permalink) Old 04-24-2020, 08:57 AM
Danman1957's Avatar
Don't believe everything you read Theo !!!
Silly Wabbit LOL
DaninVan and Stick486 like this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #20 of 26 (permalink) Old 04-24-2020, 11:03 AM
OK; you made me look it up...
They are different, in the same way that coyotes and wolves are different.
https://www.diffen.com/difference/Hare_vs_Rabbit
