PC plunge router depth gauge problem - Router Forums
post #1 of 6 (permalink) Old 01-26-2010, 07:07 PM Thread Starter
Default PC plunge router depth gauge problem
I have a porter Cable 893PKR 2 1/4 Hp router with a plunge and fixed base. I am haveing a problem with the depth gauge. It is a round rod and the depth sitting thingy keeps comming loose and falling off. I think it should have had a flat spot to tighten on. I am wondering if others had the same problem and what have they done to solve the problem?
codgerbill is offline
post #2 of 6 (permalink) Old 03-20-2010, 07:45 PM
dutchman 46's Avatar
First Name: Howard
Hello Bill; I don't know anything about that router, If there is room between the router base,and the screw holder, is there room for a small spring,(like a carburetor adjustment), and o-rings on the outside of each end of the spring. That may solve Your screw movement. Solve a problem, and not have extra monkey business with the adjusting?
John 3:16
dutchman 46 is offline
post #3 of 6 (permalink) Old 03-20-2010, 09:04 PM
Hi Bill - Welcome to the forum
Are you talking about the turret or the depth rod? I don't think there is a flat on the depth rod, there is a compression spring according to the parts list. The turret is just held down with a screw but does have a detent ball. There is a thumbscrew to tighten the rod isn't there?
John Schaben
jschaben is offline
post #4 of 6 (permalink) Old 03-20-2010, 09:16 PM
Hi Bill
It sounds like a user error thing, the thumbscrew needs to be very tight if you have the same error take the thumbscrew out and replace it a Allen or Hex head cap screw.
post #5 of 6 (permalink) Old 03-21-2010, 12:49 PM
First Name: Warren
I have a couple of those routers and they deph setting CAN get to be a PITA. Use your brass bars as much as you can. That helps. And the rest, unless there is something missing, is just something ya gotta "fiddle" with lotsa times.
Somebody on here will be able to be more helpful than I am and you may want to call a PC service center and ask them a few questions.
sourdough is offline
post #6 of 6 (permalink) Old 03-25-2010, 09:50 AM
First Name: Dave
I have the same 893 Combo....with the same problem. I just tighten the heck out of it and watch it very carefully, or it will plunge too deep.
DM
3thumbs is offline
Mounting a plunge router George II Table-mounted Routing 8 01-03-2010 02:28 PM
MSI Router - Problem silegnav General Routing 2 12-29-2009 08:56 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
Router Purchase - Mastercraft 10A Plunge Router with Table skashyap General Routing 46 07-17-2009 07:54 PM
Fixed Base or Plunge Router tdsapp General Routing 11 06-13-2009 03:55 PM
