cleaning up end grain on hardwood - Router Forums
post #1 of 20 (permalink) Old 05-24-2011, 10:31 PM Thread Starter
Default cleaning up end grain on hardwood
sorry to those of you who are now reading this for the second time. I am new to the site and may have inadvertantly sent it the worng way the first time. I installed hardwod floring 3/4" thick a year or so ago and have now decided tha I want to continue it into the next room. I had a transition strip that covered the first ends that were not perfectly lined up (off by up to 1/16"). Now I want to continue but there will be gaps if I don't get them perfectly flush. I am thinking about using a template bit 3/4 dia. 11/4 " long with a 1/2" shank and taking multiple passes. Any other thoughts/suggestions would be most helpful.
JRB
JRB The Handyman is offline
post #2 of 20 (permalink) Old 05-24-2011, 11:58 PM
JRB
Hi JRB - Welcome to the forum
Router would probably work but that is a lot of endgrain to deal with. I would be inclined to use a circular saw with a fine tooth finish blade. Lay down a guide strip for the shoe to run against and make the first cut a scoring cut (1/8" or less).
John Schaben
jschaben is offline
post #3 of 20 (permalink) Old 05-25-2011, 10:24 AM
Ralph Barker's Avatar
First Name: Ralph
I mostly agree about the circular saw with a guide rail. The practical side, however, is whether there are obstructions at either end of the saw's path. It might be easier to scribe a line with a straight edge, and cut only the "offending" boards, perhaps with a hand saw or Multi-Tool.
Depending on the layout of the original floor, you'll still have an obvious break line at the transition point. Thus, you might still want to have some sort of transition board perpendicular to the flooring strips, just to make a clean line.
- Ralph
Ralph Barker is offline
post #4 of 20 (permalink) Old 05-25-2011, 10:33 AM
Hi
I disagree with the power hand saw they like to lift the wood up and rip up the ends.I suggest you get the saw below.
5" DoubleCut Saw
post #5 of 20 (permalink) Old 05-25-2011, 11:36 AM
RJM60's Avatar
First Name: Robert
I think you should pull up some boards to eliminate the break line. Extra work and cost but the break will look pretty bad. Also, no matter how you do it, it's going to be very difficult to get a clean edge cutting installed HW flooring. A router might work if you use some double sided tape to hold a straight edge and make cuts that eliminate the break line. Clean up corners with a small chisel, etc.
Just sayin'
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #6 of 20 (permalink) Old 05-26-2011, 01:23 AM
crquack's Avatar
5" DoubleCut Saw
Interesting. Do you actually use one? There is a heated debate on another forum about it. The one guy who actually uses one likes it. The rest have many opinions based on conjecture.
Have you used it on anything else but wood?
crquack is offline
post #7 of 20 (permalink) Old 05-26-2011, 05:24 AM
debbicot's Avatar
Country: Ireland
First Name: Hugh
You could try to cut the new boards at the angle to fit into the edge of the old boards and then finish the edge off the tongue or grove , with the router too match
debbicot is offline
post #8 of 20 (permalink) Old 05-26-2011, 11:48 AM
First Name: Ralph
Hi
5" DoubleCut Saw
True of most old-style circular saws. A plunge-cut saw with a zero-clearance insert at the uplift end of the blade (e.g. Festool) would be less likely to do that.
The double-cut saw you linked looks interesting.
- Ralph
post #9 of 20 (permalink) Old 05-26-2011, 02:37 PM
Phil P's Avatar
First Name: Phil
A Festool (or Makita 5000SP, or Mafell MT55cc, or Hilti WSC255/WSC265, etc) on a rail will do exactly as Ralph says - near perfect straight cut with minimal edge splintering. What you get can often be disguised with a little bit of coloured wax (such as Liberon). Part of the trick is to have the correct blade in the machine. The ends of cut are finished using a hand saw running against a straight hardwood block and possibly paring with a sharp chisel as needed. It's the sort of set-up I use for breaking-out floors for electric/plumbing installs and minimises the amount of make good work required.
Don't know about using that Harbor Freight souped-ep angle grinder doo-hickey, though, doesn't look like it could be guided to cut a dead straight line. I've seen plumbers using them to cut access holes in floors but we joiners generally have to quite a bit of clean-up afterwards as the holes aren't always that straight. I do agree that with fresh blades they can cut cleanly - but nowhere near as good as a rail guided saw set-up IMHO
Regards
Phil
Phil P is offline
post #10 of 20 (permalink) Old 05-26-2011, 02:56 PM
YouTube - ‪Dual Saw(tm) Counter-Rotating Power Saw - As Seen on TV‬‏
http://www.youtube.com/watch?v=PI0SM...1&feature=fvwp
But who wants to put out 500.oo + for Festool..
Regards
Phil
routing end grain hardwood JRB The Handyman General Routing 5 05-25-2011 07:49 AM
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 10:03 AM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 09:32 PM
Staining end grain rstermer The Finishing Touch 11 02-21-2009 09:22 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 01:24 PM
