Perfectly round edges? - Router Forums
post #1 of 11 (permalink) Old 07-03-2011, 10:34 PM Thread Starter
Country: France
Default Perfectly round edges?
Hello there, I have lurking on the forum for a while now but I am still wondering how to complete a project I have in mind.
I intend to make an arcade stick with half-round edges. However I am still wondering where to get the appropriate bit size knowing that my project would be 10 cm in height (about 4 inches) and the biggest rounding bit I could find is only 1.5 inches in radius (and costs over 130 $ with shipping = http://www.amazon.com/Freud-34-140-Q...9744647&sr=1-1 Amazon.com: Freud 34-140 Quadra- Cut 1-1/2-Inch Radius Rounding Over Bit with 1/2-Inch Shank: Home Improvement ).
This is the result I am after:
Does anyone know where I could find a 50 mm (2 inches) rounding bit - preferably somewhere that ships to Europe?
Cheers,
-John
John Venture is offline
post #2 of 11 (permalink) Old 07-04-2011, 04:10 AM
derek willis's Avatar
First Name: Derek
I intend to make an arcade stick with half-round edges. However I am still wondering where to get the appropriate bit size knowing that my project would be 10 cm in height (about 4 inches) and the biggest rounding bit I could find is only 1.5 inches in radius (and costs over 130 $ with shipping = Amazon.com: Freud 34-140 Quadra- Cut 1-1/2-Inch Radius Rounding Over Bit with 1/2-Inch Shank: Home Improvement Amazon.com: Freud 34-140 Quadra- Cut 1-1/2-Inch Radius Rounding Over Bit with 1/2-Inch Shank: Home Improvement ).
Cheers,
-John
You could use a long cutter of 1/2" diamater with a shank of the same size,(the type used for workktop use), thus riding the shank on the template, Alternatively you could use avery large round over bit and run it across your table both sides to acheive a round finish.
Derek
derek willis is offline
post #3 of 11 (permalink) Old 07-04-2011, 08:47 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi
My feeling is that you are not going to get anything that big in a router bit. It would surely need to be well over 4" in diameter and need to be used in a table and I've doubts as to whether you'd find a suitable one. I suspect you are going to need a shaper cutter for this one.
Cheers
Peter
istracpsboss is offline
post #4 of 11 (permalink) Old 07-04-2011, 10:54 AM
TWheels's Avatar
John Venture, Welcome lurker! Very glad you have decided to join fully. There is little I need to tell about the RouterForums
I have looked at other sources (MLCS and Amana) and find no bit with a 2 in (50mm) radius. The 1 1/2 in (37.5 mm) roundover bits have 3 1/2 (87mm) diameters.
I wonder if there is another way to achieve your goal, such as a template that could use a flush trim or pattern bit. The edges might have to be done approximately 100 mm segments and then joined, but it might leave open possibilities for edges individually composed of pieces of differently colored woods.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #5 of 11 (permalink) Old 07-04-2011, 10:56 AM
Phil P's Avatar
First Name: Phil
Hi there
I have to agree with Peter. Big bits like that are all but impossible to find. A few years back there were a number of firms making these big cutters in the USA. Names which spring to mind are Furnima Industrial Carbide, Paso Robles Carbide in California, Byrom International Corp. and True-Cut Saw in Montana - all but the last name are now defunct and True-Cut now seems to specialise only in saw blades. I suppose the reason for the demise of these large cutters may be that they were aimed at the pin router market which has moved over to using spindle moulder-type cutter blocks on CNCs rather than shanked router cutters.
I've had a look through my current tooling catalogues and found nothing bigger than the Freud bit you refer to; most only go up to 25mm (1in) radius. I, too, suspect the item in the photo you posted was machined on a spindle moulder. Another possibility if you have access to a lathe would is to turn lengths of the profile in a lathe then split it (rip it down) on the table or band saw to create the half round sections you require. That it how a lot of larger diameter quadrant mouldings used in the kitchen and furniture manufacturing spheres are made. This could be a good reason to build a router lathe.............. BobJ posted some excellent links in this thread
Edit: I sat and pondered the router jig thing. For the purposes of this task a router "lathe" needs to be little more than a rectangular MDF box minus its' top. The two short ends are drilled to take a 6mm piece of threaded steel rod. The ends of each piece of timber (which needs to be 25 to 30mm shorter than the box inside) are drilled 6mm. The threaded rods are then passed through the holes and fixed in place by tightening a two nuts on each, one inside the box, one outside. That should allow the work piece to spin freely. If the router is then mounted on a piece of plywood or MDF long enough to span the box it should be possible to turn the wood whilst routing it to a perfect cylinder section. Obvious once I sat and thought about the problem for five minutes
Regards
Phil
Last edited by Phil P; 07-04-2011 at 03:32 PM. Reason: Added basic router lathe idea; spelling
Phil P is offline
post #7 of 11 (permalink) Old 07-04-2011, 12:29 PM
Phil P's Avatar
First Name: Phil
Hi Bob
They all seem to be smaller radius than the Freud 34-140 the OP mentions. Are any of the more specialist cutter manufacturers still around in the USA? I was surprised to find that a lot of the bigger cutters have disappeared over here in recent years
Regards
Phil
Phil P is offline
post #8 of 11 (permalink) Old 07-04-2011, 12:57 PM Thread Starter
Country: France
Thanks for the support everyone.
The same seller bobj3 linked to also have a 1-1/2 bit, which also happens to be much cheaper at 32$.
http://www.cgi.ebay.com/1pc-1-2-SH-1...item1e64585df0
The bit diameter wouldn't fit with my router (max is 42mm) so I would have to use a table which I don't have - still I think it's the easiest solution if I reduce the height of my project to 80 mm in order to use the 38 mm (1-1/2") bit, and then use some elbow grease to sand the remaining 2 mm.
Bobj3, out of curiosity have you tried those bits?
post #9 of 11 (permalink) Old 07-04-2011, 03:13 PM
Hi John
Yes I have all the ones I posted,,,they are good bits Not high end like Freud but they work just fine and the price is right...
I should note I have all his bits and not one dud in the lot.
post #10 of 11 (permalink) Old 07-05-2011, 05:37 PM
AxlMyk's Avatar
Form an approximate edge by sanding, whittling with a knife, table saw, whatever means you like.
Take a flat piece of steel and cut, grind, file, the profile you need. You now have a cabinet scraper to finish the job.
AxlMyk is offline
23 ga Pinning into MDF edges? BigJimAK Table-mounted Routing 58 10-15-2013 10:36 PM
How to best dress up the edges on Rockler table top? xvimbi Table-mounted Routing 2 08-06-2010 03:39 PM
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 11:14 AM
round router bases levon Jigs and Fixtures 14 05-11-2009 04:43 AM
Round over on thin curved pieces Ken Massingale Table-mounted Routing 8 09-20-2004 06:36 AM
