Bit for Round Over on Trim for Window - Router Forums
post #1 of 5 (permalink) Old 07-18-2011, 11:20 AM Thread Starter
First Name: lee
Default Bit for Round Over on Trim for Window
I am new here and new to routers. I just bought my first router, a Porter Cable 7538 on ebay for $102.50. It is missing a base plate. I want to use it to round over the trim boards on a replacement window I am installing. I was thinking of a 3/4" round over with a 1/2" shank. The boards are about 1". I don't think they are a true full 1 inch. Should I be looking for a smaller round over than 3/4"? Also do you think it would be better to router the boards before or after they are put into place. I will have easy acces once they are nailed.
Also should I just get the Porter Cable base plate?
coxhaus is offline
post #2 of 5 (permalink) Old 07-18-2011, 12:46 PM
Hi Lee - welcome to the forum
Last things first - yes, get a base plate. Don't know what a PC plate would cost but here is a good aftermarket that includes a set of guide bushings:
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
Roundover bits are spec'd at the RADIUS of the roundover so a 3/4" roundover (fairly large bit by the way) would be more appropriate on 1-1/2" material. To get a nice roundover on standard 1 by stock, actually 3/4" thick, you would want more like a 1/4" to 1/2" radius. 3/4" radius will give you a quarter round molding.
You would also want to do the routing before it is installed. I needs to be firmly secured along with any addition support needed for router stability. I would suggest doing the routing on the longest stock practicable and cut to length for installation.
Good Luck
John Schaben
jschaben is offline
post #3 of 5 (permalink) Old 07-18-2011, 04:59 PM
Phil P's Avatar
First Name: Phil
Hi Lee and welcome
Most of the window boards I install are factory profiled with a radius of between 30 and 60mm (1-1/4in to 2-1/2in). With those it is often necessary to radius the visible ends of the returned nosing (the "ears" which protriue beyond either side of the window opening) so for that I use a large diameter bullnose bit (like the T2526-1/2 here) with a plywood or MDF fence plate on the router and sand in to finish. This achieves the edge in a single pass but needs care in setting up the cutter to precisely the right height. Just as John recommends I, too, rout a longer edge than I'm going to use. I also complete all the routing work before installation
With square section (unmachined) stock I prefer to use the same (bull-nose) cutter if I'm profiling the front edges as it's a lot faster and less error prone than making two passes with a quarter round bit IMHO. I'm wary about using a quarter round cutters with bearings because on the second pass the bearing often doesn't have a flat surface to run against, depending on the thickness of the stock and radius of the cutter. And if you run the bearing against a previously radiused surface you'll probably end up with a highly visible step to sand out (not nice). If I have to do this job in the absence of my big bull nose cutter(s) then I ignore the bearing in the cutter completely and just use a plywood plate on the router fence to guide the cutter (because all my round-over bits are the bearing guided variety).
Regards
Phil
Phil P is offline
post #4 of 5 (permalink) Old 07-19-2011, 02:26 AM Thread Starter
First Name: lee
I like the idea of using a large diameter bull nose bit but I can not figure out which size bit to buy. I want to end up with a full rounded board without much step. What is a good size and bit to buy for my example above?
coxhaus is offline
Router Accident - Trying to understand what happened Darryl Shop Safety 170 07-07-2017 07:44 PM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 10:25 AM
Floor/wall Trim reds_21 General Routing 2 01-13-2006 09:52 PM
Flush Trim Bit odamsr Router Bits - Types and Usage 3 09-14-2005 07:32 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 07:50 PM
