Bosch router base/brackets - Router Forums
post #1 of 5 (permalink) Old 08-04-2011, 05:35 AM Thread Starter
First Name: Mark
Default Bosch router base/brackets
I bought a Bosch 1617EVS router to use as the spindle on a CNC router. Because it was only going to be used as the spindle, I discarded the base/brackets that let you use it as a standard router (stupid, I know, but that's the way things came down). Now I have need of these base/bracket pieces so I can use the router for other things. Does anyone have an idea where I can bet these things so that I won't have to buy a whole new router?
Thanks,
Mark
mickelsen is offline
post #2 of 5 (permalink) Old 08-04-2011, 07:22 AM
Mark, you can order the bases from any Bosch Service Center but I suggest buying another combo kit. This will give you two complete routers so you don't need to switch bases and has worked out well for me. Check on Ebay and craigslist; these bases are usually available. Note that the newest version of the 1617EVS uses an adjustable round sub base plate which requires a centering cone that is not included in most kits. This new design allows you to use your router in any position relative to your work and know your cuts will be exactly the same.
post #3 of 5 (permalink) Old 08-04-2011, 07:30 AM
CharleyL's Avatar
First Name: Charley
I agree with Mike. Unless you get lucky and find what you need used it will likely cost you more than a whole new router will to just buy the parts that you are missing. Buy a new multi base kit and use both router motors with it.
Charley
CharleyL is offline
post #4 of 5 (permalink) Old 08-04-2011, 01:41 PM Thread Starter
First Name: Mark
Thanks. I'm considering both options.
There is a 1618 D-handle base available on Ebay. Does anyone know if the 1618 base will take a 1617 motor/router?
Thanks again.
post #5 of 5 (permalink) Old 08-04-2011, 01:43 PM
Yes Mark, the model number difference indicates the D handle base. The motors are identical.
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 07:43 PM
Rigid or Bosch Router? Marcus General Routing 13 12-06-2011 01:48 AM
No Lift Systems To Fit Bosch 1619EVS 3.25HP Router? DennisP General Routing 4 01-20-2010 06:23 PM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 08:12 PM
Bosch router table using pc895 router under routerron Table-mounted Routing 2 10-06-2006 12:50 PM
