Ski planing using a 1 3/4" bottom cleaning bit - Router Forums
post #1 of 13 (permalink) Old 09-01-2011, 08:58 AM Thread Starter
RouterForums.com User
harrysin's Avatar
First Name: Harry
Default Ski planing using a 1 3/4" bottom cleaning bit
Yesterday I received my 1 3/4" bottom cleaning bit from America and had to test it straight away, with rather surprising results. It took very little time to plane the surface of this very cupped piece of Jarrah, I then, having a reference surface, cleaned-up the other side because it fitted into the planer. It could well have been flipped over and planed like the first side. On close examination I could feel small ridges in the routed side which at first puzzled me. After a while it dawned on me what probably caused it, the four corners were not EXACTLY the same height, and with such a large bit it was tilted a fraction. With a smaller straight bit this would not have been at all a problem and to prove the theory I fitted the 25mm (1") bit that I normally use and re-planed the piece and it was now perfectly smooth.
My conclusion is that if one wants to precision set the four corners of the Skis, which takes time, then the large bit would be fine, but if a quick set-up is the order of the day, then a smaller bit would be the way to go and probably be the fastest of the two.
Harry
harrysin is offline
post #2 of 13 (permalink) Old 09-01-2011, 10:18 AM
Thanks Harry, I've had the same issue using that bit in my Woodhaven jig. I hadn't taken the time to figure out what the problem was as everything sanded out fine. That was on my RoundTuit list
Thanks again.
John Schaben
jschaben is offline
post #3 of 13 (permalink) Old 09-01-2011, 05:03 PM
First Name: Al
Thanks Harry.....I was wondering as to the results of your bigger bit. I have the smaller version and it works well after a little practice.The major influence I find is dont try to take off too much ......couple of mill at the most. It may take a little longer, but the end result is far better...................AL
Al Robins is offline
post #4 of 13 (permalink) Old 09-02-2011, 01:33 AM
Thanks Harry,
I will use that trick on the jarrah I plan to use on my face frame.
Sydney, Australia
jw2170 is offline
post #5 of 13 (permalink) Old 09-02-2011, 09:23 AM
First Name: Keith
Great idea Harry,
What is the diameter of the steel rods holding the router?
Keith
The Bench Dawg is offline
post #6 of 13 (permalink) Old 09-02-2011, 09:54 AM Thread Starter
harrysin's Avatar
First Name: Harry
Originally Posted by The Bench Dawg View Post
Great idea Harry,
Keith
The diameter of the ski rods does of course depend on the size of the holes in the particular router. In the case of my Makita routers this is 12mm, a fraction smaller than 1/2". Here is a zip file on making skis.
Harry
harrysin is offline
post #7 of 13 (permalink) Old 09-02-2011, 12:52 PM
Marco's Avatar
Thanks for the Post and pic's Harry...... a 1 3/4" bit is on my list....... growing list for the shop.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is online now
post #8 of 13 (permalink) Old 09-02-2011, 04:57 PM
First Name: Al
Default Maximum Ski Height
Whilst we are on the subject of Router Skis, whats the maximum height for the cheeks. I have some large blocks that I cant put through the planer or jointer which are over 150 mm or 6 inches in height.
I can lock the workpieces down (somehow) so that is not an issue.and obviously I would have to make new cheeks which is not a problem..... Regards......AL
post #9 of 13 (permalink) Old 09-03-2011, 08:42 AM Thread Starter
harrysin's Avatar
First Name: Harry
Basically, if the slots in the end cheeks are 6" in length, then you couldn't use the skis on a project that is 10" in height. In other words the cheeks can be as tall as you wish, so long as you are tall enough to see what is happening at the bit. This is unlike the length of the rods, which if they are too long will cause sag.
For my height and the height of my bench, 13" would be about the limit.
Harry
harrysin is offline
post #10 of 13 (permalink) Old 09-03-2011, 05:09 PM
First Name: Al
Thanks Harry, that was about what I thought............AL
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
From Marc Sommerfeld's Site - Why not to bottom out your router bit BigJimAK Router Bits - Types and Usage 34 12-17-2010 10:02 PM
router bit for use with skis to thickness wood rwyoung Jigs and Fixtures 19 02-14-2009 08:22 AM
Flush Trim Bit Top Bearing vs. Bottom Bearing steveD Router Bits - Types and Usage 14 12-22-2008 01:36 PM
