a new sign using 12" skis - Router Forums
post #1 of 16 (permalink) Old 09-12-2011, 08:53 AM Thread Starter
RouterForums.com User
harrysin's Avatar
First Name: Harry
Default a new sign using 12" skis
This small sign, just 11 1/2" x 2 5/8" was made using a very small ski, only 12" wide.
It's the first time that I've used this ski which was made as a forum project and I'll add a zip file showing it's making. I doubt that I'll be using it again, compared to my full size ski which is 27 1/2" wide, it was hard work. The lack of mechanical advantage which is afforded with the big ski made control of the router little better than if I was using the router's own handles, several letters had rippled edges which I had to clean with a chisel. I used a 3/16" bit which just fitted between the letters and I removed the background as I went along, unlike the larger signs where I rout the outlines first then change to a larger bit to remove the background.
Harry
harrysin is offline
post #2 of 16 (permalink) Old 09-12-2011, 09:33 AM
Hi Harry
Nice job Mate
Have you tried
HP Iron-On Transfers (12 Transfer Sheets, 8.5 x 11 Inch)
Just get your banding iron out and transfer the image right to the wood..
Amazon.com: HP Iron-On Transfers (12 Transfer Sheets, 8.5 x 11 Inch): Home Improvement
http://www.amazon.com/Avery-Personal...ef=pd_sbs_op_2
By the way I like the Shellac look best
http://www.routerforums.com/attachme...ski-sign12.jpg
post #3 of 16 (permalink) Old 09-12-2011, 11:31 AM
Dal300's Avatar
First Name: Dallas
Harry,
I'm not sure if this would work for you but, at one time I was asked to make the number signs for the camping spots in our RV park.
Nothing fancy, just some 1X6, cut into a rectangle then a 22.5 miter on each end.
My method was to line print what ever number I wanted, you can do this with Notepad by setting your font to print "outlines".
Once I had the numbers printed, I used a utility knife to stab/transfer the pattern to the wood, then went over the small marks in the wood with a "Sharpie" ultra fine point felt tip marker.
From there I used a simple ski about the same as you did.
It worked well and easily, although there was a bit of a learning curve to make the router do as I wished.... we have 32 sites, plus 10 of the sites are pull through from either end, so I ended up with 42 signs. By the time I had the third site number done, I had most of the process under control.
Just my way, YMMMV.
DF
Dal300 is offline
post #4 of 16 (permalink) Old 09-13-2011, 08:11 AM Thread Starter
harrysin's Avatar
First Name: Harry
Hi Harry
Nice job Mate
Have you tried
Amazon.com: Avery Personal Creations InkJet Iron-On Dark T-Shirt Transfers, White, Five Sheets per Pack (03279): Office Products
I'm not sure that there is much to interest me in those transfers Bob. Regarding the finish, I fully agree with you about the Shellac, however, a sign is meant to be seen, and the Shellac finish became invisible at quite a short distance, hence the contrasting paint job.
Harry
harrysin is offline
post #5 of 16 (permalink) Old 09-13-2011, 08:15 AM Thread Starter
harrysin's Avatar
First Name: Harry
Originally Posted by Dal300 View Post
Harry,
Just my way, YMMMV.
DF
Dallas, if I hadn't previously routed signs using full size skis I almost certainly wouldn't have had reason to complain, but the difference in control between the two is dramatic!
Harry
harrysin is offline
post #6 of 16 (permalink) Old 09-13-2011, 08:25 AM
Hi Harry
Most wood signs are made for the blind a touch thing
post #7 of 16 (permalink) Old 09-13-2011, 11:23 PM Thread Starter
harrysin's Avatar
First Name: Harry
Hi Harry
Methinks that routing dots, where six dots equal one letter in the Braille language would be the way to go for the sight impaired Bob.
Harry
harrysin is offline
post #8 of 16 (permalink) Old 10-03-2011, 12:05 PM
First Name: Trent
harrysin, do you move the ski frame itself up and down the letters as you route out the sign or do use adjusters to move the router itself top to bottom of the sign?
If you use adjusters then it might work well to have tracks parallel to the top and bottom of the board for the ski to sit in for moving left to right and a bit of weight added on top so they do not slide too easily or try and lift as the bit bites down.
There is definitely an advantage to a small sized ski in my shop as long as it is usable without a lot of difficulty.
the_nite_owl is offline
post #9 of 16 (permalink) Old 10-04-2011, 09:33 AM Thread Starter
harrysin's Avatar
First Name: Harry
The skis are operated by firmly holding the ski ends as shown and the router, which is positioned then locked to the rails, can be moved in all directions. A dummy run should be carried out to ensure that the skis aren't going to drop off the bench top!
Harry
harrysin is offline
post #10 of 16 (permalink) Old 10-17-2011, 01:30 PM
First Name: Burt
Hello Harrysin - I am retired and I make signs for fun and give them away. I do my workup on a computer and then transfer that to a piece of cedar. Then I hand rout the sign - depending on the size of the letters of course depends on the size of the bit that I use. What really caught my eye was the router sled - the question that I have for you is this - did you make the sled or was it commercially made - if you made same do you happen to have plans that you would consider sharing. Burt - Chilliwack BC
burshar is offline
Sign making Idea's? RouteringRookie Starting Off 9 04-28-2016 01:28 PM
Routing with the aid of Skis Tom76 Jigs and Fixtures 2 05-18-2010 05:07 PM
Sign material & Sign templates Gunpowder Sign Making 1 09-18-2008 06:30 PM
how to use skis - other devices? allthunbs General Routing 1 08-15-2008 03:22 PM
