router as chainsaw carving - Router Forums
post #1 of 7 (permalink) Old 09-20-2011, 10:35 PM Thread Starter
First Name: andy
Default router as chainsaw carving
Okay, so this is a little unusual, but I think I am at the right forum. I do chainsaw carving in stumps or logs of pine and fir, big things like bears and fish, I want to try a heavy duty router. Do I go electric or pnuematic? Seems pnuematic might spin faster, and be more efficient? What size, in HP, and arbor size? I know there is some knowledge outther, suggestions???
Andy
andyrose is offline
post #2 of 7 (permalink) Old 09-20-2011, 10:47 PM
kp91's Avatar
First Name: Doug
You might want to try a cutter like these.
Copy Carver Burrs - Saburr Tooth Carving Burrs
As for air or electric powered routers, I've got a Sioux air router and it takes an enormous amount of air to keep it at speed. You've got to have almost an industrial size air compressor to keep up with it if you are going to run it any length of time.
Either an electric or pneumatic die grinder would probably be a safer and better alternative. The HF electric one might not be heavy duty enough, but is put here for an example. I have Dayton and Ingersoll air powered die grinders, and they too use a lot of air, but not as much as the router.
http://www.harborfreight.com/electri...aft-44141.html
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 7 (permalink) Old 09-20-2011, 10:57 PM
I have never seen a pneumatic one although that doesn't mean there aren't any. Electric would be cheaper and no air source needed. Electric is limited to about 1800 watts or 3 1/4 to 3 1/2 hp according to manufacturers specs. The more power, the harder to control.
No matter what size, you will be limited in depth of cut. Also, a router is not meant to be held freehand in midair. That's why they have a base on them. A dremel would be good for fine detail, but I think your primary weapon is still going to be the chainsaw. By the way, a full size Porter Cable router is as heavy as my old 98cc Stihl 066 without bar and chain.
post #4 of 7 (permalink) Old 09-21-2011, 07:22 AM
First Name: Ian
Have a look at this gear, google Arbortech. Its cutters are based on chainsaw cutting action. It is an Aussie product but is available in the US from most major woodworking suppliers.
Its on you tube also, well worth a look.
Cheers, Ian
Nanigai is offline
post #5 of 7 (permalink) Old 09-21-2011, 10:41 AM
bobbotron's Avatar
First Name: Rob
Andy
Arg, this sounds pretty dangerous, I think I'd stick to the chainsaw!
bobbotron is offline
post #6 of 7 (permalink) Old 09-21-2011, 11:04 AM
post #7 of 7 (permalink) Old 09-21-2011, 01:03 PM
Pneumatic routers are primarily used for shaping Granite and other stone surfaces where water is in use and creates an electrical hazard potential. Andy, for your application a large 3-1/4 hp plunge router could be used for making cavities if used with a template and guide bushings. Routers are very difficult to control free hand let alone on a rough surface. A power carving tool would be a better choice for you.
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
Router carving question: acordasco Starting Off 5 10-05-2009 09:35 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 03:45 AM
