Dewalt collet & nut - Router Forums
post #1 of 20 (permalink) Old 10-24-2011, 12:21 PM Thread Starter
Default Dewalt collet & nut
Will any other power tool brand collet and nut fit a Dewalt 618 router
new to routering is offline
post #2 of 20 (permalink) Old 10-24-2011, 02:42 PM
Good question. It is possible but would require checking them all out. Replacement collets are easy to get from the DeWalt service center and can be ordered from any store that sells them.
post #3 of 20 (permalink) Old 11-27-2011, 03:37 PM
First Name: Joe
If you can figure out the thread and pitch and cross reference with other brands it's easy to get the right part.
Finding the thread and pitch of the different brands of course is the hard part.
But once you know the thread size it should be easy to find one that will work.
Assimilator is offline
post #4 of 20 (permalink) Old 11-27-2011, 04:54 PM
Honored Member
First Name: pat
Pretty much an exclusive in your case. The one exception, DW 621 uses matching collets and nuts.
Quillman is offline
post #5 of 20 (permalink) Old 03-17-2012, 03:42 PM
Country: Brazil
First Name: Paulo
I'm in Brazil, I bought 10 years ago one DW621 that came with 1/4" and 1/2' shank collets using 22mm nut size. Later Dewalt changed for 6mm and 8mm shank collets and 17mm nut size. I cant understand why, since in USA it cames with 1/4 and 1/2 collets.
Router bits here aren't easy to buy.
I have a box of Freud router bits ( 6mm shank ) and I'm having a lot of dificulties to buy Router collet 6mm with 22 mm nut. Anyone knows where I can buy collets to fix in my router??
GaspardPaolo is offline
post #6 of 20 (permalink) Old 03-18-2012, 05:14 AM
ggom20's Avatar
Country: France
First Name: Gerard
Hello!
Not easy to find collets metric for that!
One way to solve your problem is a reduction sleeve 1/2" to 6mm
exist also 1/2" to 8mm I use them for years with my 1/2 ryobi routers
1/2 to 8mm:
Trend CLT/SLV/8127 Collet Reduction Sleeve | Miles Tool & Machinery Centre
1/2 to 6mm:
Trend CLT/SLV/6127 Collet sleeve 6mm to 12.7mm Collet sleeves
That's the idea, now maybe better shop USA for you , or ebay.
Regards
ggom20 is offline
post #7 of 20 (permalink) Old 03-18-2012, 11:36 PM
Country: Brazil
First Name: Paulo
Merci Gerard
My router is GB made and cames with collets 1/4" and 1/2" and nut 22mm as in USA actually, for other markets, later they have changed the collets for 6mm, 1/4" and 8mm but with nut 17mm.
Today DeWalt call my collets 'obsolete'
Router manufacturers think they are selling client first router.
Only with Festool is possible find several collets dimensions.
post #8 of 20 (permalink) Old 03-18-2012, 11:48 PM
4 pc Collet Reducer Bushing for 8mm, 1/4" Router Bit | eBay
4 pc Collet 12mm Reducer for 8mm, 1/4" Router Bit | eBay
post #9 of 20 (permalink) Old 03-19-2012, 04:52 AM
ggom20's Avatar
Country: France
First Name: Gerard
Hi bob!
GaspardPaolo Said:
-"My router is GB made and cames with collets 1/4" and 1/2" "
And he wants to use 6 mm Metric Freud bits and maybe buy also one for 8mm.
So this links you gaveis for a pair of 1/2" to 8mm:
and a pair of 1/2" to 1/4"
Bob your links are no use to find a 1/2" to 6mm...
Found this page, cheap and they got it all :
Lee Valley Tools - Important Announcement
Regards
ggom20 is offline
post #10 of 20 (permalink) Old 03-22-2012, 12:54 PM
ggom20's Avatar
Country: France
First Name: Gerard
Clic that link then clic continue:
Regards
ggom20 is offline
Stuck Collet Dewalt 625 ogee General Routing 12 11-10-2018 11:56 AM
Router collet nut dj92 General Routing 11 11-09-2009 03:03 PM
Where buy 1/2" collet DeWalt 621? charleyb General Routing 5 10-07-2009 10:37 PM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 01:33 PM
Elu MOF31 nut and collet daki222000 Portable Routing 6 10-20-2008 02:18 PM
