What causes scorching? - Router Forums
post #1 of 5 (permalink) Old 01-03-2012, 12:16 PM Thread Starter
First Name: Tim
Default What causes scorching?
Absolute newbie (to routing) here. Received a router for my birthday, and as a first small project, made a screwdriver holder out of scraps I had from other projects. Figured I could learn a little about my new tool, and clean up my workbench at the same time. I ended up with some scorching on the pieces I was routing (edge decoration, one piece with cove, another with ogee). Especially the end grain on a piece of poplar.
All of my bits are brand new, never used before. What causes scorching? Is it pace (too slow or fast)? After the first bit of scorching, I started making the cut in multiple passes that did seem to reduce things a bit.
Thanks in advance....
LitchfieldHills is offline
post #2 of 5 (permalink) Old 01-03-2012, 01:18 PM
BrianS's Avatar
First Name: Brian
Hi Tim. Welcome to our little corner of the 'net.
Normally scorching or burning is caused by to slow of a feed rate. Or, as you found on in your last paragraph, too big a bite.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 5 (permalink) Old 01-03-2012, 01:21 PM
Tim, several things can cause scorching. Many times it can be a dull bit or one that has a build up of wood sap/resin. In your case it is most likely speed. This can be moving the router too slowly or the bit speed being too fast for the type of wood. Experiment a bit and you will get it right.
post #4 of 5 (permalink) Old 01-03-2012, 02:07 PM Thread Starter
First Name: Tim
So in this case, going super slow to be careful actually works against me. Thanks for the advice.
post #5 of 5 (permalink) Old 01-03-2012, 08:13 PM
Hi Tim - Welcome to the forum
Well, in a word, yes. But, going slow to be careful isn't necessarilly a bad thing either. What you can also do is slow the bit speed to match your feed pace to also reduce the burning. I do that quite a bit routing signs as I'm always slowing and stopping to make corners and such.
John Schaben
jschaben is offline
Scorching RCarter New Member Introductions 5 09-24-2007 06:17 PM
Wood scorching during cut?!!! Birch Tools and Woodworking 8 04-01-2007 08:56 AM
