router bit - Router Forums
post #1 of 4 (permalink) Old 02-04-2012, 12:00 PM Thread Starter
First Name: ed
Default router bit
was recently watching ask this old house and tommy was using a router bit with the bearing on top cutting blades below. he was doing a hinge mortice with a template the same size as the hinge. what is that bit called and who has them ?
thanks Ed
ed in idaho is offline
post #2 of 4 (permalink) Old 02-04-2012, 01:05 PM
Ed, when the bearing is on the end of the bit it is called a flush trim bit. When the bearing is on the shank end of the bit it is called a pattern bit. You can view some of them here: MLCS Flush Trim and Shear Angle Flush Trim Router Bits
post #3 of 4 (permalink) Old 02-04-2012, 01:28 PM
Hi Ed
The one I like and the best one I have came with the kit below, just made for that type of job..just a note you can also use the templates for Small hinges as well..by putting a small insert (press fit) into the template..made with scrap wood you have around the shop.
Amazon.com: Milescraft 1213 Complete Door Mortising Kit: Home Improvement
" Includes a durable tungsten carbide tipped 1/2-Inch router bit with ball bearing, eliminating the need for guide bushings"
thanks Ed
post #4 of 4 (permalink) Old 02-04-2012, 01:57 PM Thread Starter
First Name: ed
thanks for the imformation, i've got one coming from MLCS
Ed
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 05:18 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 10:46 AM
