Use router on nylon sheets - Router Forums
post #1 of 11 (permalink) Old 03-27-2012, 12:56 AM Thread Starter
Country: India
First Name: Shabbir
Default Use router on nylon sheets
Friends,
Hello !
I am totally new to Routers. Some of the raw materials I need to work on are plastic sheets like Nylon, HDPE, UHMW-PE, ACRYLIC, PP, Etc.
Can anyone guide me whether I can use Routers to cut these plastic sheets ?
Has anyone tried this before and with what result ?
Warm Regards
Shabdhin
Shabdhin is offline
post #2 of 11 (permalink) Old 03-27-2012, 01:16 AM
First Name: Chris
Wlecome!
My understanding is that that is the sort of thing the variable speed routers are made for. When routing plastics and other soft materials that can melt, you would set the speed low to help keep the heat down.
I don't know about the very hard plastics though, I'd worry they might shatter. Hopefully, someone who know about those material will chime in.
Chris Curl is offline
post #3 of 11 (permalink) Old 03-27-2012, 06:44 AM
GulfcoastGuy's Avatar
First Name: Patrick
Successfully shaped all edges on this with the three flute Smooth-Edging Carbide-Tipped bit (#5 Here)from Mcmaster Carr #35505A65. ... Cast acrylic.
IMG_3524 by pat w1, on Flickr
GCG
GulfcoastGuy is offline
post #4 of 11 (permalink) Old 03-27-2012, 10:04 AM
Honored Member
First Name: pat
Routers are made to manage plastic; it's the primary tool for plastic fabricators. A flat learning curve, have little fear. However, take the "new" in stages and use new cutters.
Speed (RPM) is not a critical variable. I rout at full speed and never melt stock whether cutting blind inside or full or fractional edge cuts.
Quillman is offline
post #5 of 11 (permalink) Old 03-27-2012, 02:25 PM
kp91's Avatar
First Name: Doug
Ive routed nylatron and delrin without any trouble
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 11 (permalink) Old 03-27-2012, 03:31 PM
hal
First Name: hal
In th past week there have been several questions about routing acrylics and other man made materials and I think they have been answered adequately so I wont go there,but I have found a tip that I think will help everyone who uses acrylics or plastic in there jigs or projects.
Drilling holes in these materials sometimes have a way of braking the part, fusing the part to the bit or not looking very good. So the anwer is to regring your bit. Chuck the bit that you need into your reversable drill and place it in reverse. Turn on your bench grinder and hold your drill at about a 60 degree angle and run the drill. You don't have to use a lot of pressure, a light touch is best.
I read this tip one night about midnight and was so struck by it I went out to the shop and tryed it. It was quick, simple and worked great.
So here is where I found this great tip. www.instructables.co, go to Tools and look for (foolproof, easy drill bit sharpening for acrylic) by Mike D. If I was really computer literate I would put in a thread. Some day when I can't work in my shop maybe I will try to figure out how to do all these great things on the computer. Everyone have a great day.
d
hal is offline
post #7 of 11 (permalink) Old 03-27-2012, 03:55 PM
Foolproof, Easy, Drill Bit Sharpening for Acrylic
http://www.instructables.com/pages/s...ng+for+acrylic
post #8 of 11 (permalink) Old 03-29-2012, 01:53 PM Thread Starter
Country: India
First Name: Shabbir
Originally Posted by Shabdhin View Post
Friends,
Hello !
Warm Regards
Shabdhin
Thanks All ! So nice of you !
My question is answered. Soon I will begin my project.
Warm Regards
Shabdhin is offline
post #9 of 11 (permalink) Old 06-05-2014, 05:24 AM
First Name: Jahson
hi Shabdhin,
its not a very difficult task to cut the Nylon sheet its very easy you can use any heating equipment and many other items available in the market you can get it............
The plastic makers is offline
post #10 of 11 (permalink) Old 06-06-2014, 11:19 PM
RainMan 2.0's Avatar
I cut very thick nylon (3") on my table saw with no issues using a standard Carbide blade. Sorry as I've never tried it with a router so I'm not a lot of help here. Sure leaves a mess though
RainMan 2.0 is online now
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 11:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 05:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 07:39 AM
