DW 611 Collet Tightness - Router Forums
post #1 of 6 (permalink) Old 04-18-2012, 02:16 PM Thread Starter
Ken Bee's Avatar
First Name: Ken
Default DW 611 Collet Tightness
I have a new DW 611 Kit and the collet for it is nearly impossible to insert a bit into even when fully off the shaft and hand held. I tried cleaning the collet with a brass collet brush and cleaning the bit with no notable difference. I even used a piece of 600 grit sand paper on the bit, still no go. I did get a bit into the collet but had to use a pair of pliers to get it out. I had thought about running a 1/4 drill bit through it but wasn't sure if that is a good idea at the risk of causing damage to the collet.
Any suggestions on how to overcome this minor problem?
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #2 of 6 (permalink) Old 04-18-2012, 03:22 PM
First Name: Duane
I think if it was mine I would return it. Shouldn't be that tight!
Dmeadows is offline
post #3 of 6 (permalink) Old 04-18-2012, 04:43 PM
First Name: Warren
I noticed mine was tight but NOT that tight. I agree, try to return it.
sourdough is offline
post #4 of 6 (permalink) Old 04-18-2012, 05:30 PM
Hi
It will be ,you just need to use it more and it will free up.
post #5 of 6 (permalink) Old 04-18-2012, 06:01 PM
Ken, sometimes the collets get closed up during the packaging process. Remove the collet and put the shank end of a drill bit which is slightly smaller into it and pry it open a small amount. It doesn't take much to make a world of difference.
post #6 of 6 (permalink) Old 04-19-2012, 02:03 PM Thread Starter
Ken Bee's Avatar
First Name: Ken
To Duane and Warren,
I should return it just because it has a tight collet? I think not. If it wasn't running or had a broken part, maybe, but not for a tight collet.
Thanks to BJ and Mike,
I will try both suggestions when I decide to change bits. As with all my routers they are dedicated to one task as is the DW 611. I bought it for Inlays only and once again I am here to tell you the router is state of the art and I now have a new favorite trim router.
Thanks again for all the input guys.
Ken Bee is offline
Broken Router Collet deanr Table-mounted Routing 12 10-26-2012 01:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 08:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 01:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 11:51 AM
