Square base plate for mortising/dadoing - Router Forums
post #1 of 13 (permalink) Old 09-26-2012, 07:39 PM Thread Starter
Send a message via Skype™ to NoChatter
Default Square base plate for mortising/dadoing
I am wondering how many people if any use this method. The reason I ask is that I just finished my first real mortise and noticed how the tracking can vary just by twisting the router maybe an eighth of a turn. I am using a PC with a stock round base plate but I am going to make a square b/p for the next attempt.
Name:	Router Plate.jpg
NoChatter is offline
post #2 of 13 (permalink) Old 09-26-2012, 07:48 PM Thread Starter
Default Schematic for jig
Name:	Base Schematic.jpg
post #3 of 13 (permalink) Old 09-26-2012, 07:59 PM
Hi Mike,
Any base with at least one square side will help to eliminate that error.
Using the "fractionating baseplate" from Bill Hylton's "Router Magic" will help to get an exact fit.
Sydney, Australia
jw2170 is offline
post #4 of 13 (permalink) Old 09-26-2012, 10:57 PM
Honored Member
First Name: pat
No question, a square/rectangular subbase is a method of constant edge to cutter cut.
I use it, but only on outside cuts. Sooner or later the plate bottoms out on the templet and the cut is complete no matter how willy nilly I handle the router. It's hard to find constants in routerdom and this is one of them and should be exploited.
Notwithstanding, any deviation with a straight line subbase on an inside cut will result in a spolied cutter pathway. You're trading one set of responsibilities for another!
Quillman is offline
post #5 of 13 (permalink) Old 09-27-2012, 12:58 AM
Harrison67's Avatar
First Name: Harrison
Yep, square is the way to go.
Harrison
Harrison67 is offline
post #6 of 13 (permalink) Old 09-27-2012, 10:53 AM
Mike, everyone assumes the round sub base plates are centered on their routers and that is rarely the case. There are several methods for centering your router on it's sub base plate or on a mounting plate: centering cones, a inlay bushing with alignment pin or the Rousseau $5 centering kit. They all work; I like the Rousseau kit best.
post #7 of 13 (permalink) Old 09-27-2012, 09:31 PM
Question
Mike, do you know where one can obtain a Rousseau centering kit?
Do the transfer screws come in different sizes? I would like one for the Makita and one for the Triton.
I have several new base plates to add to routers (aka BOBJ3) and want to make sure they are centered for guide bush use.
Sydney, Australia
jw2170 is offline
post #8 of 13 (permalink) Old 12-02-2012, 11:35 PM
TRN_Diesel's Avatar
Buy Base Plate Centering Kit 1 at Woodcraft
TRN_Diesel is offline
post #9 of 13 (permalink) Old 12-03-2012, 06:12 AM
Thanks Dan. I note they only ship to the lower 48.
I think I will find Mike's post on making your own plate and use that as a guide to correctly centre the plate.
Sydney, Australia
jw2170 is offline
post #10 of 13 (permalink) Old 12-03-2012, 10:00 AM
James, you should be able to find the transfer screws at a hardware store. If you want to order the Rousseau kits send them here and I will forward them.,
Making your own sub base plate Mike Guide Bushings and Templates 84 03-02-2015 08:16 AM
Base Plate for Craftsman Router Steve1946 Craftsman 12 12-04-2014 07:22 PM
making a base plate help please ? Tazkb Guide Bushings and Templates 7 11-25-2011 06:14 PM
The Marvel 3 in 1 tool from MLCS: base plate and table mount advice please loninappleton Table-mounted Routing 4 07-10-2010 09:32 PM
