Drop Leaf Rule Joint Using 1.5 Inch Stock - Router Forums
post #1 of 7 (permalink) Old 10-03-2012, 08:57 AM Thread Starter
First Name: Fred
Default Drop Leaf Rule Joint Using 1.5 Inch Stock
Hello All
I am making a a kitchen island with a butcher block top. The solid prefab maple top is over sized so I would like create a drop leaf with the excess. Most drop leafs I have seen are made with with three quarter inch stock thickness using half inch cove/cope bits. The butcher block I am using is one and a half inch stock. Can I still use the half inch cove/cope bits and just change my hinge placement? Thanks for all of your help.
Fred Rainer
TallFred is offline
post #2 of 7 (permalink) Old 10-03-2012, 09:30 AM
First Name: del
Originally Posted by TallFred View Post
Hello All
Fred Rainer
I don't belive that will work with thick stock. The 3/4" when you use the bit's when you bring the side up it matches the top piece. I have made a few drop leaf tables and all 3/4". If you use the bit on the botton of the wood you have it will not match the top it will be to thick. As the 3/4" when you swing it up it match's the top. The hinge is a drop leaf hinge not like a reg. hinge. one side is shorter than the other. my 2 cents look up the drop leaf hinge and you will see what i look's like
del schisler
port st. lucie, florida
del schisler is offline
post #3 of 7 (permalink) Old 10-03-2012, 01:49 PM
GulfcoastGuy's Avatar
First Name: Patrick
I'm no authority since I've never tried one but the profile seems to allow for the vertical face (above the round over/cove) to be as long as needed. Just use a standard sized rule joint set and a suitable drop leaf hinge properly positioned and mortised. You'd just need to be aware that the drop portion would extend that amount from the outer edge of the stationary portion.
GCG
GulfcoastGuy is offline
post #4 of 7 (permalink) Old 10-03-2012, 01:57 PM
First Name: Patrick
After a second look I see it may not be as easy as I first thought. The cove cut would be straight forward enough. But the round over might require a rabbit to remove some waste and maybe an collet extension to reach the piece.
GCG
post #5 of 7 (permalink) Old 10-03-2012, 02:11 PM
First Name: Patrick
Here's a pic of what I was thinking of from another forum.
Routing a drop leaf joint?
GCG
post #6 of 7 (permalink) Old 10-03-2012, 03:00 PM
Guest
First Name: Regis
Fred,
The hinge placement does not change with board thickness. The center of the hinge pivot is in line with the vertical face of the leaf, You will have to cut that flush with the flat created above the quarter round by that bit. Same with the cove side. Here' a link to a fairly heavy hinge set. You might want more than one pair. If you use brass screws, prefit with steel screws and then replace one at a time with the brass screws.
Rule Joint Hinges-Paxton Hardware
You'll also need a hefty support for the extended leaf. Good Luck!
Regis
48394 is offline
post #7 of 7 (permalink) Old 10-04-2012, 06:51 AM Thread Starter
First Name: Fred
Thanks to everyone for helping me figure this out. After a few practice set ups with scrap 2 x 4s it looks like the problem is solved.
Fred Rainer
TallFred is offline
Beech drop leaf table mailee Show N' Tell 8 04-27-2009 03:47 PM
The correct drop leaf router bit set Doverwood Table-mounted Routing 14 02-06-2009 03:00 PM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-22-2007 12:13 AM
mortises for 2 inch stock joe carter Jigs and Fixtures 2 05-30-2005 08:22 AM
Drop leaf table Maurice Table-mounted Routing 6 11-10-2004 12:45 AM
