Milescraft template kit problem - Router Forums
post #1 of 15 (permalink) Old 11-28-2012, 07:25 AM Thread Starter
First Name: Chris
Default Milescraft template kit problem
I got a Milescraft template kit yesterday. It says it is compatible with Ryobi routers, and I have 2 of their plunge routers. The Ryobi routers are threaded to accept a 5/16" bolt. I found some holes in the plate that line up with the holes in the router, but they are too shallow and not wide enough for the head of the 5/16" bolts.
Does anyone else have this problem, and what would you do to solve it, grind the head of the bolt down, or make the hole bigger and deeper?
If I can't find a bolt that fits, I think I'd prefer to grind one over modifying the plate.
Chris Curl is offline
post #2 of 15 (permalink) Old 11-28-2012, 08:50 AM
ve7tcc's Avatar
First Name: Duncan
I went to my local hardware store and found compatible bolts for use with the base plate.
It says you need only 2 bolts, and you can use some of the slots so you can center it correctly.
ve7tcc is offline
post #3 of 15 (permalink) Old 11-28-2012, 09:03 AM Thread Starter
First Name: Chris
thanks. i'm going to one over my lunch break.
post #4 of 15 (permalink) Old 11-28-2012, 09:52 AM
First Name: Ben
I have also had some problems with my Freud 1700 router. The screws supplied were the wrong size. With the new base the original screws were too short.
In addition the diagram showing the mounting hole locations were incorrect. I did finally find longer bolts after several trips to local hardware stores. After a while I also found three locations to bolt the new base plate to. As previously stated the printed information showing the bolt hole locations was incorrect.
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #5 of 15 (permalink) Old 11-28-2012, 10:17 AM
dutchman 46's Avatar
First Name: Howard
Good Morning! I don't have MilesCraft plates, kits! When I do run into a problem, I look for cap bolts. The ones that I have are crimped, so to speak. The surface around the the bolt has no wrench openings, They are all set to be ale to use adjustable pliers, and a Allen wrench. They have a shoulder, but not oversized. They fit very nice whenever a reg bolt doesn't work
John 3:16
dutchman 46 is offline
post #6 of 15 (permalink) Old 11-28-2012, 10:29 AM Thread Starter
First Name: Chris
howard, i think i know the kind of bolts you are talking about. good point ... i'll keep in mind to look for them
post #7 of 15 (permalink) Old 11-28-2012, 10:31 AM
ve7tcc's Avatar
First Name: Duncan
I used the template kit on this project recently:
http://www.routerforums.com/show-n-t...ox-friend.html
ve7tcc is offline
post #8 of 15 (permalink) Old 11-28-2012, 12:35 PM Thread Starter
First Name: Chris
well, home depot had some 5/16" rounded head cap bolts that are pretty close, so i got them. i will still need to grind them a little to get them to fit.
on the way home, time permitting, i'll stop at the true value. hopefully they will have other options.
post #9 of 15 (permalink) Old 11-28-2012, 03:06 PM
Exclamation
Hi Chris,
I have that problem as well with some of my 3rd party base plates.
The trick is not to use the mounting screw holes for the original base plate.
For example, for the Makita 3612C, I use the screw holes for the guide bushing.
As you can see in the attached photo, I have marked the holes on the universal base plate to allow me to use standard brass guide bushings.
PS I have my Milescraft template kit on the way from Peachtree, due any day...
Sydney, Australia
jw2170 is online now
post #10 of 15 (permalink) Old 11-28-2012, 04:12 PM Thread Starter
First Name: Chris
hmmm. IIRC, the screw holes for my Ryobi are small holes near the opening, and none of the holes in the Milescraft plate are even close to them. I will have to look again.
Milescraft sign kit gumball Sign Making 72 03-28-2016 01:30 PM
Using a portion of a template to make a project kp91 Guide Bushings and Templates 2 06-08-2012 02:45 PM
Cutting Board, Rounded Corners w/Juice Groove bradleyjere Guide Bushings and Templates 16 09-20-2011 09:48 PM
Milescraft Design and inlay kit # 1207 StanSR New Member Introductions 9 04-26-2010 04:26 PM
Template Routing FlyFAmerica Portable Routing 11 12-21-2008 12:36 PM
