Routing a small circle on a small board. - Router Forums
post #1 of 11 (permalink) Old 02-25-2013, 12:55 AM Thread Starter
First Name: Brook
Default Routing a small circle on a small board.
Hello all,
I am brand new to the forum and a relative novice to wood working. I am trying to route a small circle (not all the way through) on a board and have no idea how to make a perfect circle.
The project is on a small board (plaque size) that will lay flat on a desk, the hole indentation is to hold a vase. I would like to post a picture but as I am new I can't post pictures yet. I traced the outline of the jar and used my Bosch palm router to do the circle freehand. Needless to say I am disappointed in the freehand technique. The circle is small (about 4in across) which would put center point under the plate, so I can't think of how I could use a router compass.
Any help would be greatly appreciated.
Brook
swartzwalker is offline
post #2 of 11 (permalink) Old 02-25-2013, 04:59 AM
Default circle jig
Hello,
And welcome to forum
Try this http://www.routerforums.com/jigs-fix...tting-jig.html
and if not happy with that one then use the search box and type in circle jig
Lots of threads will then appear with circle jigs there are a couple of awfully complicated ones from France and Ukraine but most of them are fairly simple and broadly similar.
The photos will explain themselves.
Bill
steamingbill is offline
post #3 of 11 (permalink) Old 02-25-2013, 08:51 AM
First Name: Art
That is a very small circle to try cutting with a jig. I would make a template out of mdf using a hole hole saw to make sure that it is perfectly round . Then put a bushing in the router, set the depth of the cut and plunge away.
mgmine is online now
post #4 of 11 (permalink) Old 02-25-2013, 11:30 AM
On vacation
Brook, I do that type of routing all the time. Here is what I use and it works great and easy to setup. Could not post url but if you go to MCLS and search on their Daisy Pin router. Good luck
4042 is offline
post #5 of 11 (permalink) Old 02-25-2013, 01:38 PM
First Name: Dick
Howdy Brook, it would help if you would fill out your profile so members would know what tools you have available to accomplish what you want to do. Art is right, you can simply make a jig out of 1/2 in. MDF with a hole saw or circle cutter, and use a guide bushing or a top bearing bit to cut the circle then clean out the center with the same bit. A top bearing hinge mortising bit would work great for this, most of them will cut up to a 1/2 in. deep some deeper.
Willway is offline
post #6 of 11 (permalink) Old 02-25-2013, 03:38 PM
JOAT's Avatar
First Name: Theo
Yep, the more details the better.
I'd cheat. I'd probably use a hole saw, and make a hole in a piece of wood, all the way thru. Then I'd glue a bottom on the wood. Presto, all done.
JOAT is offline
post #7 of 11 (permalink) Old 02-25-2013, 05:23 PM
Exclamation
I agree, Art. (or use a circle jig to make the template).
I would use a dish cutter to give a rounded edge to the bottom of the cut out.
MLCS Dish Cutters, V-Groove, Sign Lettering, Router Letter Template Set
Also 4" is not too small for a circle jig.
http://www.routerforums.com/jigs-fix...ircle-jig.html
Sydney, Australia
jw2170 is offline
post #8 of 11 (permalink) Old 02-25-2013, 08:51 PM
Gaffboat's Avatar
First Name: Oliver
Originally Posted by swartzwalker View Post
Hello all,
Brook
As others have said above, a simple circle jig will work. I cut the a 1 1/2 radius (3 inch circle) slot in the top of my recent automaton project [http://www.routerforums.com/show-n-t...-man-shop.html] with quickly made circle jig. The small size was not a problem.
Gaffboat is offline
post #9 of 11 (permalink) Old 02-25-2013, 09:20 PM Thread Starter
First Name: Brook
Default Thank you for the support!
Thank you all for the input!
I didn't know there was a place for me to show my tools, I will set that up, thanks for the tip.
I am not exactly sure what a lot of these terms are but I now have a starting point to look up the terms, thank you for the heads up.
I did consider using a circle cutter to make the outline and then route the inside, or as you suggested to make a MDF template, the big problem I found with this was that the size of the base isn't an exact 4 inch cut out.
Brook
post #10 of 11 (permalink) Old 03-04-2013, 08:22 AM
First Name: Art
If you need a different size then use a fly cutter in a drill press if you have one.
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 02:29 PM
Routing a semi circle top for a picket fence village General Routing 19 05-30-2009 10:46 PM
Circle routing newbie48 General Routing 6 10-20-2008 04:22 AM
routing small pieces zxxer12 General Routing 9 03-21-2005 04:40 PM
end of board routing alanjoel General Routing 3 12-11-2004 07:50 AM
