A simple trinket box tutorial - Router Forums
 3Likes
post #1 of 18 (permalink) Old 02-25-2013, 07:34 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Default A simple trinket box tutorial
This series of photographs shows how I went about making a simple trinket box. At the end I'll add a pdf of the project. The box measures 9" x 4.5" x 8.25" tall.
Continued next post
Harry
harrysin is offline
post #2 of 18 (permalink) Old 02-25-2013, 07:41 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Continued from previous post
File Type: pdf A trinket box made from Tasmanian Myrtle.pdf (3.05 MB, 162 views)
jj777746 likes this.
Harry
harrysin is offline
post #3 of 18 (permalink) Old 02-25-2013, 08:03 AM
Big Steve's Avatar
First Name: Steve
Great display of the project Harry, thanks. Tasmanian Maple sounds so exotic, probably more so here in the states.
Steve
Richmond, Virginia
Big Steve is offline
post #4 of 18 (permalink) Old 02-25-2013, 05:58 PM
Thanks Harry. A timely reminder to get out to the shed.......
Sydney, Australia
jw2170 is offline
post #5 of 18 (permalink) Old 02-25-2013, 07:57 PM
First Name: Earl
Thanks Harry--seems a simple idea to use a 45 degree bit to cut miter corners, but i'd have never figured that out on my own. Looks like a sink cut-out you used for the design template, i'm guessing that you have a variety of offset inserts already cut for what ever comes to mind?
earl
greenacres2 is offline
post #6 of 18 (permalink) Old 02-25-2013, 08:17 PM
Marco's Avatar
Nice work and tutorial Harry!
Curious to your mark on the bottom of the box. Was it hand written, routed, burned, etc.?
Galatians 5:13
Marco is offline
post #7 of 18 (permalink) Old 02-25-2013, 11:35 PM
BRAVOGOLFTANGO's Avatar
First Name: Bravo
Thank you Harry, I love these from aromatic cedar and would love to try out my new box joint jig to make one of these.
Excellent work sir.
BRAVOGOLFTANGO is offline
post #8 of 18 (permalink) Old 02-26-2013, 06:18 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
earl
I haven't Earl because this one is designed specifically for a 9" x 4.5" lid and further variations can be made by changing the size of the template guide and/or bit. For the one shown I used a 25mm guide and because I used a 45 "V" bit, adjusting the height alters the width of the cut. Such a jig can be made on a bigger scale for things like draw fronts, in which case further variations are possible.
Harry
harrysin is offline
post #9 of 18 (permalink) Old 02-26-2013, 06:22 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
I wrote it on paper Jim then placed it with carbon paper on the box after which I went over it with a ball pen. It's the first time that I have used this method, I normally do it freehand with a marking pen. Pros. like Bobj3 and some other members use a custom branding iron.
Harry
harrysin is offline
post #10 of 18 (permalink) Old 02-26-2013, 06:27 AM Thread Starter
Honored Member
harrysin's Avatar
First Name: Harry
Excellent work sir.
I may well make the next one using box joints using the most simple of jigs, the spacer jig. Whilst the one that I'll use is a commercially available one made by Oakpark that I won some years ago on this forum, kindly donated by Bob Noles, it is so easy to make and use.
Harry
harrysin is offline
My first box dkneifel Show N' Tell 19 02-08-2016 09:10 AM
Trinket Box project for Mothers Day SignCrafter Show N' Tell 9 03-09-2012 02:09 AM
simple box joint jig julianhall Jigs and Fixtures 16 01-03-2012 11:30 AM
How to Make a Simple Clock Using Box Joints learnexperience Tools and Woodworking 2 08-15-2011 10:21 AM
Curved profile trinket box Brisso57 Show N' Tell 9 08-12-2011 03:57 PM
