Taking on Extreme Angles - Router Forums
post #1 of 3 (permalink) Old 04-08-2013, 12:22 AM Thread Starter
First Name: Keith
Default Taking on Extreme Angles
Some projects present us with creating half lap dados with extreme angles. Your first thought may be, "...no worries, I'll just use a table saw...". A potential challenge could be that your table saw will not easily support pushing wood through the blade at such angles with any precision.
The solution? Use a portable router with a guide to make the cuts at the outer boundaries of the dado. We will call these your money cuts.
Install two screws in the router base and advance them deep enough underneath the base, in this case about 1/2". Press the router up against the guide so the two screws touch the edge of the guide. Measure the distance between the guide and cutting edge of the router bit. In this example, it was coincidently 1-inch. Use a ruler or tape to measure 1-inch away from the desired "money cut" edge in two separate locations. Place your guide edge along these two reference points. Clamp in place. Drag your router along this guide at your desired depth throughout your cut length. Repeat this procedure on the other side of the dado. Now you have two parallel dado cuts opposite each other.
Take your piece to the table saw and dado the remaining portion of the dado between the two money cuts. Pay special attention to keep the dado saw blade away from your two new router-created cuts throughout the dado process.
Viola' ... precise fit dado!
PorterCable690 is offline
post #2 of 3 (permalink) Old 04-08-2013, 08:56 AM
Shortslvs's Avatar
First Name: Fred
I love it when people use their brain and then post what they did, so when I need to do it I don't have to use my brain
Shortslvs is offline
post #3 of 3 (permalink) Old 04-08-2013, 11:19 AM
This would be much easier with guide bushings. Using your router without the sub base plate can mar the surface of your material.
Can you cut 45 degree angles with a router bit? jchutch75 Router Bits - Types and Usage 17 01-30-2012 11:37 PM
???? about angles papawd Starting Off 14 03-27-2011 08:45 AM
Seeking Chart showing DT Angles garycurtis Router Bits - Types and Usage 6 10-10-2010 05:54 PM
compound miter angles gdemo Tools and Woodworking 4 11-23-2009 03:40 AM
Extreme birdhouse # 16 (new) cranbrook2 Show N' Tell 29 07-02-2006 10:11 AM
