router bases - Router Forums
post #1 of 9 (permalink) Old 07-21-2013, 03:31 PM Thread Starter
First Name: Alan
Default router bases
I have a dewalt dwp611 router and just purchased a frued rabbiting bit 13/8 diameter. Can't adjust depth due to a smaller hole in base plate. do I cut A larger hole in my new base or is there a better solution? Your advise would be appricated. Alan
endercat is offline
post #2 of 9 (permalink) Old 07-21-2013, 05:28 PM
JOAT's Avatar
First Name: Theo
I don't know if you're 'supposed' to do that, but I would.
JOAT is offline
post #3 of 9 (permalink) Old 07-21-2013, 05:50 PM
Semipro's Avatar
First Name: John_*
Alan
Go to the top of page watch Mikes vedio on making a new sub base, you can make them any size, use any 1/4" material,center hole any size
Semipro is offline
post #4 of 9 (permalink) Old 07-21-2013, 07:34 PM
Smile
Originally Posted by Semipro View Post
Alan
+1
Sydney, Australia
jw2170 is offline
post #5 of 9 (permalink) Old 07-21-2013, 08:33 PM
Hi
Just take off the base plate and use it without for this one job it's no big deal at all..
http://www.amazon.com/DEWALT-DNP613-...alt+611+router
post #6 of 9 (permalink) Old 07-21-2013, 10:13 PM
Alan, don't cut your plate... you will need it for use with guide bushings. It is easy to make a new sub base plate. The sub base plate helps provide balance and prevents marring your material. Depending on the job you can use BJ's tip, I would suggest having a second piece of material the same thickness as your workpiece in front of the work to help balance your router.
post #7 of 9 (permalink) Old 07-22-2013, 04:45 AM
MAFoElffen's Avatar
Tip if not using a plate. If I do that, I tape off the bottom with blue masking tape. Just a couple strips seems to do fine. That way I don't add black aluminum marks to my work.
On circular saws with aluminum platforms, aluminum router table plates, aluminum router & saw tables... I use paste wax. Just saves from having to sand those aluminum marks off.
MAFoElffen is offline
post #8 of 9 (permalink) Old 07-22-2013, 07:09 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Try the MLCS 9465 1/2-Inch Shank Router Collet Extension and Wrenches from MLCS or Amazon ~ 30.00 I can not live without mine now that I have one. Best Part, you do not like it you send it back and get your money back.
Good Luck - Baker
rwbaker is offline
post #9 of 9 (permalink) Old 07-22-2013, 09:20 AM
Honored Member
First Name: pat
"Your advise would be appricated. Alan"
Subbases for the 611.
Quillman is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Show us your Router Bases thething84 General Routing 2 01-17-2013 07:29 PM
New here burlboy New Member Introductions 9 01-15-2009 12:53 PM
GMC Router 2 1/4 HP $47.49 3 bases ???!! Joe Lyddon General Routing 59 03-21-2007 12:50 PM
