Guide Bearing Problems - Router Forums
post #1 of 9 (permalink) Old 11-03-2013, 05:50 PM Thread Starter
First Name: Warren
Default Guide Bearing Problems
I was using a 1/4 round over bit with guide bearing on cedar. I got a nicely rounded edge with one flaw. The guide bearing left a shallow path (the width of the bearing) on every single piece of wood. Any ideas?
ExpressEN1 is offline
post #2 of 9 (permalink) Old 11-03-2013, 06:02 PM
Could you have been pressing the bearing too hard against the timber?
Sydney, Australia
jw2170 is offline
post #3 of 9 (permalink) Old 11-03-2013, 08:49 PM
Hey,Warren; an old restorers trick is to use a steam iron to gently swell the wood where it's dented, then let it dry out again. Just be careful not to scorch the wood with the heel of the iron. Maybe lay a piece of wet cloth over the edge and iron that to get a lot of instant flash steam and a bit of heat...no scorching. Should work like a charm on Cedar.
DaninVan is offline
post #4 of 9 (permalink) Old 11-03-2013, 08:51 PM Thread Starter
First Name: Warren
That is entirely possible. I'm still new at this and I almost never use my hand router.
post #5 of 9 (permalink) Old 11-03-2013, 09:15 PM
Sounds like it's time to replace the bearing,Cedar is very soft but if the beaning is running free you should not see any burns/rub marks...
If the beaning is ok do it on the router table to take most of the load off the bearing..
post #6 of 9 (permalink) Old 11-03-2013, 09:31 PM
Honored Member
First Name: pat
You are pulling the router too hard.
The unit forces are too high and emboss soft wood.
Slacken up, halve the unit force x adding another bearing.
Quillman is offline
post #7 of 9 (permalink) Old 11-04-2013, 02:18 AM
Warren; what the other guys said. I was just referring to the damage already done.
DaninVan is offline
post #8 of 9 (permalink) Old 11-04-2013, 04:28 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
BJ your answer is exactly correct. NGM
neville9999 is offline
post #9 of 9 (permalink) Old 11-04-2013, 06:28 PM Thread Starter
First Name: Warren
This is a new bit and the bearing rolls nice and smooth. I think adding a second bearing to increase the contact area as well as not holding the router so tight against the material might solve my problem.
I tried the iron trick and it worked pretty good. Another set of lessons learned.
Thanks for the help folks.
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 02:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 12:44 PM
Guide bushing or guide bearing??? argentum Jigs and Fixtures 8 10-08-2012 06:53 AM
Router Bearing Guide newwoodworker Shop Safety 5 12-05-2010 06:00 AM
guide bearing realtor.bt Starting Off 0 11-14-2008 02:35 PM
