routing mortises - Router Forums
post #1 of 4 (permalink) Old 12-15-2013, 07:25 AM Thread Starter
carl.p's Avatar
Country: South Africa
First Name: carl
Default routing mortises
Hi all please I need some advice I am routing mortises in legs for a work bench the legs are 65mm x 90mm am routing from the 90mm side have gone down to 26 mm how much further should I take the mortise down as mortise is 22.3mm wide. regards carl.
Classical music is food for the mind and soul.
carl.p is offline
post #2 of 4 (permalink) Old 12-15-2013, 01:40 PM
Semipro's Avatar
First Name: John_*
Carl
http://www.woodworkersjournal.com/up...non_Primer.pdf
Thank You John
Semipro is offline
post #3 of 4 (permalink) Old 12-15-2013, 05:24 PM
Carl, as long as you are not meeting another piece that is 90* to the one you are working on then you can go all the way through if you want.
post #4 of 4 (permalink) Old 12-16-2013, 07:24 AM Thread Starter
carl.p's Avatar
First Name: carl
Hi Chuck thanks for that pdf it cleared up the confusion that was bugging me it has been a great help. regards carl
carl.p is offline
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
End Mills Used for Routing Mortises jimcrockett Router Bits - Types and Usage 8 01-28-2013 09:33 AM
Routing Mortises for a Headboard/Footboard FordTrax General Routing 6 11-26-2012 01:04 PM
Plunge Routing Deep Mortises & Kick Back aronson General Routing 8 03-24-2012 07:41 PM
Routing Mortises FARMER40 General Routing 3 10-13-2010 07:49 AM
