Template Guide for Bosch 1617 - Router Forums
post #1 of 14 (permalink) Old 03-23-2014, 02:44 PM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Default Template Guide for Bosch 1617
I recently bought my first router - Bosch 1617 EVSPK. As I am learning to use it, I now want to buy template guides and am rather confused. As I understand, I need to buy the RA1126 in order to use Bosch guides and need to add the RA1100 to use threaded guides, such as PC guides. Amazon reviews of the Bosch guides seem to be mixed. PC guides seem to be more standard. And then there are brass guides. And sub-base centering pin and cone. All rather confusing at this point and may just be personal choice. Also, what size templates would you recommend for starters - and are there metric sizes available in the US?
Lots of questions - opinions, guidance and recommendations from forum members will be most appreciated!
hankh is offline
post #2 of 14 (permalink) Old 03-23-2014, 04:12 PM
Semipro's Avatar
First Name: John_*
Hank
The PC is the standard, brass is soft if it contact the bit less damage, if can afford the price both system would be nice but if one is all you get then go PC it will fit more applications and jigs
http://m.youtube.com/watch?v=uo3zaassX9g&autoplay=1
Thank You John
Semipro is online now
post #3 of 14 (permalink) Old 03-24-2014, 08:07 AM
First Name: Richard
+1 with John
Shop guy is offline
post #4 of 14 (permalink) Old 03-24-2014, 11:46 PM
Hank, Bosch metric guide bushings are not available in the US and it may be that the SAE sizes are not available in Europe. Because of your location you might be best off getting a Trend UniBase for your 1617. Trend offers a very large selection in metric sizes and a set in SAE sizes. The router in the photo is an MRP23EVSK with the UniBase attached.
If you choose to go with the Bosch accessories then the RA1151 centering cone is a very good idea. The RA1126 is the quick release adapter which mounts between the motor and the sub base plate. Bosch guide bushings or the RA1100 adapter with a PC style guide bushing is inserted from the bottom. I think the Bosch set up is best when used with PC style bushings of brass. These brass sets are available from many sources and I prefer the sets with all the collars the same length. This way you only need one thickness of template material. I highly recommend that you use the dust collection accessories with your router, I use them with mine and they do a good job. This is part number RA1173AT.
post #5 of 14 (permalink) Old 03-31-2014, 12:53 PM Thread Starter
hankh's Avatar
Country: Israel
First Name: Hank
Thanks, Mike.
Sounds like the Trend system is the way to go for me. Is this what you are referring to?
Trend Unibase Universal Sub-Base with Pins and Bushing –
Trend Euro Style Plastic Metric Guide Bushing Set, 12 Piece (evens)
(copied from Woodcraft site). If I understand, the sub-base requires using Trend bushings, but this is not a problem as they cover the field in both metric and SAE sizes. I will check with a local forum about availability in Israel.
hankh is offline
post #6 of 14 (permalink) Old 03-31-2014, 01:18 PM
Honored Member
First Name: pat
Can accommodate in PC/DW, freight could be prohibitive, however.
Quillman is offline
post #7 of 14 (permalink) Old 03-31-2014, 06:00 PM
Pat's base plate is high precision and would be a good choice but as he said shipping might be a deal breaker. The UniBase has an adapter which uses PC style bushings.
post #8 of 14 (permalink) Old 11-03-2014, 11:47 AM
First Name: Joe
Hi Mike,
I have the 1617 plunge and fixed base and am looking for a guide bushing set. I also have the centering cone and Ra1126. I think i should just get the RA1100 and go with the brass PC bushings. What is a good set with collars the same depth? The Rockler set is variable depth and some reviewers say you need extra long shanks to use them so they are out. I want to use standard length inch bits I already have.
Thanks Joe
Joesf is offline
post #9 of 14 (permalink) Old 11-03-2014, 06:51 PM
PhilBa's Avatar
First Name: phil
There is also the option of making your own subbase. I did that for a bosch router I got for approximately nothing at auction. fairly easy to do with the instructions that Mike and others have provided. Using it with my PC compatible bushing set.
PhilBa is offline
post #10 of 14 (permalink) Old 11-04-2014, 12:38 PM
First Name: Joe
Does anyone have the shop fox or Kempston 99006 guide bushing sets? Looking at both just wondering if one is better than the other?
Joesf is offline
Bosch 1617 template guide oodges Guide Bushings and Templates 9 12-14-2011 06:13 AM
proxxon template guide? miserybob Guide Bushings and Templates 3 07-08-2009 04:43 PM
Harbor Freight 10 piece template guide set rstermer Tool Reviews 4 06-29-2009 06:29 AM
Workout the offset for a template guide opelblues Guide Bushings and Templates 5 04-29-2009 11:44 AM
