Router and bit for planing - Router Forums
post #1 of 20 (permalink) Old 04-30-2014, 10:01 PM Thread Starter
Default Router and bit for planing
I am fairly new to routing and have been using an old Craftsman router so far. The Craftsman has been giving some issues due to its wear and age so I am in the market for a new router. The main purpose I will be using it for is planing lumber with my sled. I have been interested mainly in the Porter Cable 690 and 892. A few have directed me toward the Magnate Surface cleaning bits for this job but they come in a few different sizes.
As of right now I am mainly working with oak stock around 4" wide. Can anyone give advice on which router of the 2 and which bit and size would be best for this job?
Thanks in advance!
lttoler is offline
post #2 of 20 (permalink) Old 04-30-2014, 11:01 PM
Semipro's Avatar
First Name: John_*
Thank you for your first post.
Here is what was said on the router forum
http://www.routerforums.com/router-b...-safe-use.html
Thank You John
Semipro is online now
post #3 of 20 (permalink) Old 04-30-2014, 11:31 PM
More power is better. If you plan on doing a lot of planing you should start thinking about a thickness planer. In the long run it will be cheaper to operate.
post #4 of 20 (permalink) Old 05-01-2014, 02:21 AM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is online now
post #5 of 20 (permalink) Old 05-01-2014, 07:04 AM
Selwyn Senior's Avatar
First Name: Peter
Welcome to the group.
Selwyn Senior is offline
post #6 of 20 (permalink) Old 05-01-2014, 08:21 AM
Gene Howe's Avatar
First Name: Gene
Welcome to the forum, N/A.
If you plan to use the large Magnate 2707, a 3 hp router would be advised.
I use a bowl bit for planing end grain or easily chipped wood like curly maple. Otherwise, a planer is your best bet.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #7 of 20 (permalink) Old 05-01-2014, 08:46 AM Thread Starter
Thanks for the replies and welcomes! I was actually planing on using the Magnate 2704 1.25 bit and getting the 2.25 Porter Cable 892 unless anyone steered me in a better direction. The Craftsman router was working okay for planing but the depth control was starting to bind up with each use and I was using a 1/2 dovetail bit which I'm sure is not the most efficient.
I definitely plan on getting a planer but I'm wanting to ease my way toward that direction.
lttoler is offline
post #8 of 20 (permalink) Old 05-01-2014, 12:29 PM
Honored Member
First Name: pat
890 is too top heavy for extraordinary long shallow run cutting.
690 would be better. & better yet: A hand plane and then the planer or thickness sander.
Quillman is offline
post #9 of 20 (permalink) Old 05-01-2014, 12:41 PM Thread Starter
Thanks for the input. At the moment I don't think a hand plane is in the cards. Should the 690 be able to handle the 1.25 surfacing bit? I forgot to mention but the stock I'm dealing with will be no longer than 5' in length. I plan to get more equipment as my work progresses.
lttoler is offline
post #10 of 20 (permalink) Old 05-01-2014, 02:29 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Ittoler.
Welcomne to the forum. PC690 is my favourite. I use a 0.75 inches bit.
We, woodworkers are everywhere!!!
papasombre is offline
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Ridgid Router Easy Above Table Bit Change shawnpatt Table-mounted Routing 1 03-06-2009 04:58 PM
