Roundover bit advice - Router Forums
post #1 of 4 (permalink) Old 05-16-2014, 10:28 AM Thread Starter
First Name: Bob
Default Roundover bit advice
Hi: I've got to say this is one of the reasons I love the web.
I need some helpful advice about portable routing and BINGO!
A site and forum devoted to routers! Gotta love it and thanks
all for the venue and hopefully a little wisdom!
OKAY...
Have a small, portable router with a 1/4 inch shank.
I used it once a couple years back to trim all the laminate
I put on a cabinet I had built to hold recording gear. It worked
great and I was amazed that I even did it because it came out so well.
NOW...I just purchased a 2' x 6' butcher block surface that's 1 1/2 inches thick.
I need to round one of the long sides because I'll be using it as a recording-desk of sorts.
AT FIRST...I figured I'd get a 3/4 inch round over bit but I don't
think a 1/4 inch shaft is strong enough...nor my little router for that matter.
Should I just get a 1/2 inch bit? I guess I'm also going to have to
pick up some C-Clamps for a template guide. (Any thoughts here appreciated too)
've never worked with a round over bit and will probably practice on scrap first.
Not sure how to start the cut. ALSO...thought I read somewhere that I should
move the router in an opposite direction of the way it spins???
ANY AND ALL HELP VERY MUCH APPRECIATED! I suppose if it's too difficult to
do I could always try to find a small woodshop and have them put it on their table...but that takes all the fun out of it. Thanks, Bob
bhp2000 is offline
post #2 of 4 (permalink) Old 05-16-2014, 11:33 AM
kp91's Avatar
First Name: Doug
Bob,
If you're just looking to ease the edge to make it comfortable to work at, a 3/8 inch roundover bit would work fine.
Roundover bits are bearing guided, so you can get by without using a template guide. You can use an edge guide, either store bought or shop made, to keep the router from tipping. A shop made offset sub base also works well for this.
You could also put an oversize bearing on your roundover bit so it takes a smaller bite on the first pass, or start with a smaller roundover bit and work up to your final size.
The feed direction on the router is always feeding the wood into the 'flat' face of the carbide. There are a ton of threads on the forum with examples of this if the small pictures dont suffice.
Good luck with the project!
Name:	edge guide.jpg
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 4 (permalink) Old 05-16-2014, 11:37 AM Thread Starter
First Name: Bob
Doug:
Most helpful and that's exactly what I'll do.
Thanks so much for the quick and meaningful advice!
Bob
bhp2000 is offline
post #4 of 4 (permalink) Old 05-16-2014, 08:38 PM
Semipro's Avatar
First Name: John_*
Bob, glad to see you join our community
Thank You John
Semipro is offline
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 10:25 AM
I need some rail and stile bit set advice Jack Wilson General Routing 9 03-18-2011 10:00 PM
3/4 inch pine, what roundover bit? Karter Router Bits - Types and Usage 9 02-21-2011 05:57 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 04:17 PM
3/4" Radius roundover bit with 1/4" shank chrisogrady Router Bits - Types and Usage 8 04-01-2005 09:08 PM
