Stackable Slot Cutter with top bearing? - Router Forums
post #1 of 5 (permalink) Old 05-29-2014, 02:05 PM Thread Starter
First Name: Joshua
Default Stackable Slot Cutter with top bearing?
I'm hoping this is the appropriate forum for this. In the attached sketch, I show a joint that I do quite a bit for a knockdown bed corner. It's a variety of tongue and groove, cut along the width of 4/4 material. I first do a 3/8"w x 1/4"d on piece 1. Then I dial in the appropriate rabbet on piece 2. It's not a really difficult thing to do; but I was wondering, given the variable of stock thickness, if (using a router dedicated to this task) I could modify a stacked slot cutter to have a top bearing which would ride along the tongue, and provide a consistent 3/8" space, so I wouldn't need to dial in, and I could simply grab the dedicated router and get to work?
Sketch B shows the corner having used a traditional tongue and groove cutter, which ensures accuracy, but leaves less stock at the already weak point.
So my question is practicality, but especially safety.
Thanks in advance
Josh
JDSW is offline
post #2 of 5 (permalink) Old 05-31-2014, 03:09 PM
rickjb's Avatar
You can do this on a router table with no problem. Am I to assume that you are looking to do this "in the field", thus looking for the bit you described?
rickjb is offline
post #3 of 5 (permalink) Old 05-31-2014, 06:24 PM
Honored Member
First Name: pat
Would not used stacked slotters.
Their overlap is a little sloppy and they're
unnecessarily large in diameter.
Not recommended x this author.
Quillman is offline
post #4 of 5 (permalink) Old 06-02-2014, 12:57 PM Thread Starter
First Name: Joshua
Not necessarily in the field, but I'm routing on the end of an 84" piece, so I'd find it easier to use a handheld.
Basically, looking for a way to ensure a 3/8" tongue every time, given the limitation of the size of the piece. If it were smaller, I'd fit it on the table saw or router table no problem.
Thanks for the answers,
Josh
JDSW is offline
post #5 of 5 (permalink) Old 06-03-2014, 07:46 PM
First Name: Duane
Many tongue and groove bit sets are available. Here is on example...
Tongue & Groove Assembly - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits
Frankly though, I'd use the router table.
Dmeadows is offline
Adding a miter slot to a phenolic top Danimal61 Table-mounted Routing 10 05-13-2012 07:47 AM
Weatherwatch derek willis Show N' Tell 10 03-16-2011 08:21 AM
Flush Trim Bit Top Bearing vs. Bottom Bearing steveD Router Bits - Types and Usage 14 12-22-2008 02:36 PM
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 03:02 AM
