How to cut a ractangle on a plastic pipe - Router Forums
post #1 of 15 (permalink) Old 06-13-2014, 04:43 AM Thread Starter
Country: India
Default How to cut a ractangle on a plastic pipe
I need to cut 2"X3" rectangle on a plastic pipe. How can I do this using a plunge router
gangulyraj is offline
post #2 of 15 (permalink) Old 06-13-2014, 05:28 AM
old55's Avatar
First Name: Ross
Welcome to the forum. I'm sure someone will come along and answer your question.
Ross,
old55 is online now
post #3 of 15 (permalink) Old 06-13-2014, 06:48 AM
Honored Member
harrysin's Avatar
First Name: Harry
Is the pipe round, square or rectangular and what are it's dimensions?
Harry
harrysin is online now
post #4 of 15 (permalink) Old 06-13-2014, 02:18 PM
Danman1957's Avatar
If it' a pipe then it's round. Shapes are called tubes.
I would hold it in a vise and drill some holes after punching with a awl and the try a small straight bit or a jig saw or a Dremmel type tool. If you have many then make a jig.
Good luck.
Danman1957 is offline
post #5 of 15 (permalink) Old 06-13-2014, 02:39 PM
make a three piece V block to rest on the pipe...
cut a rectangle in the flat 1st compensated for a bushing or net size it for a bearing guided bit ...
clamp the V blovk on the pipe and have at it...
post #6 of 15 (permalink) Old 06-13-2014, 03:46 PM
Garyk's Avatar
First Name: Gary
It would be a lot simpler to use a jig saw, multi tool or a Dremel tool. A router without building a jig would be dangerous and probably not very controllable. IMO.......
Garyk is offline
post #7 of 15 (permalink) Old 06-13-2014, 05:15 PM
After bit more thought...
your jig could be in the shape table..
the pipe rests/held in place between the legs and the router rides on the top...
post #8 of 15 (permalink) Old 06-13-2014, 06:34 PM
Apparently N/A has solved his question(?)...
I'm with Gary; starter holes and my jigsaw. That would be my weapon of choice.
Maybe use a 2" holesaw to gain access into the pipe (2" x 3" )
DaninVan is offline
post #9 of 15 (permalink) Old 06-13-2014, 11:35 PM
Honored Member
harrysin's Avatar
First Name: Harry
Good luck.
I'm about to stand in the corner for five minutes.
Harry
post #10 of 15 (permalink) Old 06-14-2014, 03:51 AM
RainMan 2.0's Avatar
I wouldn't use a router , I'd use my Fein . Just love this tool !
FEIN MultiMaster - Mobile
RainMan 2.0 is online now
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 12:11 PM
tip for cheap home made pipe clamp bench supports italian biker Jigs and Fixtures 7 06-15-2010 10:44 AM
Now, how I cut my tnons with a router. derek willis Table-mounted Routing 11 01-27-2009 10:51 AM
Sold: Hitachi M12V router with acessories Bob N Woodworking Classifieds 22 06-15-2007 11:35 AM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 01:56 PM
