New to Routers Advice Needed ? - Router Forums
post #1 of 4 (permalink) Old 06-21-2014, 01:50 AM Thread Starter
Default New to Routers Advice Needed ?
I've been building guitars part time for many years. Mostly all of the work I've done by hand except for a small trimmer. I recently bought a Maktec MT362 [ handyman quality within my budget ] and checked out how to zero it etc before setting the depth of cut.
My biggest query is that while this router has a "depth scale" on the body, there's no marker/pointer on the depth screw to show depth of cut relative to the scale.
I realise I can use calipers to set a depth between the bottom of the depth screw and one of the stops but why would a company produce a router that has no way of judging increments of depth without having to keep checking with calipers ?
Maybe I'm over thinking this however about to start working on some fairly expensive Alder to make the body which I had to import into Australia and I want to keep mistakes to a minimum.
Andy54 is offline
post #2 of 4 (permalink) Old 06-21-2014, 01:55 AM
I would use a "know" object between the depth screw and the stop.
A drill bit or a set of brass set up bars...
I never user the depth scale....
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 06-21-2014, 02:28 AM
Honored Member
harrysin's Avatar
First Name: Harry
Like James, I have NEVER used the built-in scales in any of the routers that I've owned. Everyone has twist drills which are very accurate. when routing the full depth of the work-piece an off-cut of the same material is what I use. Here are a few shots from projects that I've posted showing methods to suit the occasion.
Harry
harrysin is offline
post #4 of 4 (permalink) Old 06-21-2014, 03:02 AM Thread Starter
Well it looks like I was over thinking the use of the "depth scale".
So it's just as easy as a few old drill bits to get incremental depths of cut ?
Thanks so much fellas, I *really* was over thinking the whole situation.
Andy54 is offline
Advice on routers worth - Multicam M-1 wgrogers CNC Routing 10 04-29-2014 01:43 AM
Newbie intro - advice needed DarrenWK New Member Introductions 3 09-01-2013 08:35 PM
Advice needed for spiral & pattern bits please cagenuts Router Bits - Types and Usage 4 05-10-2010 02:20 AM
Bandsaw advice needed Bob N Tools and Woodworking 7 06-07-2005 03:15 PM
Advice Needed denisd Portable Routing 3 09-28-2004 01:55 PM
