Tenon routing - Router Forums
post #1 of 12 (permalink) Old 07-03-2014, 02:56 PM Thread Starter
First Name: Chris
Default Tenon routing
I'm beginning a project of relative complexity that will involve a large number of tenons on the same board(s).
I've done a few google searches for trimming tenons with a router but I was wondering if you all had specific suggestions of your favorite ways in which to clean up a tenon? I don't mind rough sawing to a line but I want to leave it fat by at least 1/16" because I'm not that confident in my sawing just yet. I'd like to use a router to clean up the cheeks and shoulders of the tenons.
Any one have favorite links? Quick jigs, etc? Precision is needed but bonus points if it doesn't require a complex jig!
Thanks in advance for the suggestions.
biocmp is offline
post #2 of 12 (permalink) Old 07-03-2014, 03:38 PM
Rogerdodge's Avatar
First Name: Roger
I use a sharp Shoulder Plane - old fashioned but it works for me.
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #3 of 12 (permalink) Old 07-03-2014, 07:15 PM
Honored Member
First Name: pat
Just to show you what you can do with only a router, no saws.
But the jig is semi-complex so I won't get into that.
Quillman is offline
post #4 of 12 (permalink) Old 07-03-2014, 09:08 PM Thread Starter
First Name: Chris
Hi quillman,
You certainly have my interest. Do you have more to share about your jig? The tenons look great.
biocmp is offline
post #5 of 12 (permalink) Old 07-04-2014, 07:10 AM
Bodger96's Avatar
First Name: Bob
Hi I built the pantorouter by Mattias Wandel woodgears.ca. This jig works incredibly well and is very durable, I have cut at least 700 tennons of various sizes on this and it still works great.. I took about 20 hours to build this but it is worth it. It will do many other joints besides mortise and tennon.
Regards Bob
Bodger96 is offline
post #6 of 12 (permalink) Old 07-04-2014, 10:13 AM
Honored Member
First Name: pat
Well the jig/fixture is a platform that supports the router.
To that platform is attached a panel to hold and index the work.
It is essentially a T-section with surfaces ~12 x 16 x 3/4 MDF.
A window in the top panel exposes the end of the stock, (held on end).
The criticalites are the squareness of the construction and parallelism of the support panel. If parallel, edge guides can be used off of all 4 sides to make tenons of any section independent of the work's section or condition.
The router hardware references directly off of the jig. If the jig is well made & the work well prepared, the tenons will be parallel to the surfaces of the sample. The working concept is referencing, secondary, tertiary etc. If the surfaces of the jig are well situated to each other, square and flat, then the work will be well referenced to the work edges of the jig. And in turn, the router, cutter, and edge guides will find the work & rout its tenon faces & shoulders as if directly referenced from its surfaces. (Like a rabbet cutter bearing works directly off the edges of a panel.)
I did have some long (4") arbors, bearings and rabbet bits made so I can also work right from the surfaces of the of the work. (Samples).
So bottomline; it's a platform jig, the work is situated vertically, presented to the router through a window in the jig, and the tenons are routed referencing the work, the jig or both. Any section possible using edge guides or bearings. Plans in an out of print book of mine, "Fast, Easy, Accurate, Router Jigs", a phoney title the editors thought might sell!
Quillman is offline
post #7 of 12 (permalink) Old 07-08-2014, 04:09 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Maybe this can help you.
http://www.routerforums.com/jigs-fix...imple-jig.html
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 12 (permalink) Old 07-08-2014, 07:30 PM
Gene Howe's Avatar
First Name: Gene
Just a note. Pat's book is available at Amazon. I just bought it.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #9 of 12 (permalink) Old 07-09-2014, 11:38 PM
Al B Thayer's Avatar
First Name: Al
I recently posted my "Shop Built Mortise Machine" here. I'm new and don't know how to post the link but you can find it in my profile or search under the above title. It also cuts tenons. Very fast. Didn't cost much to build.
If you have a lot to cut you might try the floating tenon like I did for six dining chairs. Also in the thread.
Al
Al B Thayer is offline
post #10 of 12 (permalink) Old 07-09-2014, 11:44 PM
First Name: Al
try this one. I've seen the video. better than store bought.
Great Jigs: The Four-Faced Tenon Jig | Tom's Workbench
Al
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 08:31 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 04:18 AM
Loose Tenon Routing Missouri Boiler New Member Introductions 1 07-30-2012 02:36 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 05:24 AM
