trimmer router vs dremel with plunge base - Router Forums
post #1 of 7 (permalink) Old 12-19-2014, 12:04 PM Thread Starter
paduke's Avatar
Default trimmer router vs dremel with plunge base
Could some of our luthier brothers share their experiences and advise comparing a dremel tool vs a trimmer router for inlay work
paduke is offline
post #2 of 7 (permalink) Old 12-20-2014, 03:17 AM
old55's Avatar
First Name: Ross
Bill I'm sure someone will be able to help.
Ross,
old55 is online now
post #3 of 7 (permalink) Old 12-21-2014, 01:00 AM
First Name: Frank
This is a good question, but I think this is a. It like trying to compare apples to oranges. One would have to know the work to be to make a valuable and fair comparison. Just my thought on this. Think about or just disregard it
Tagwatts1 from Utah
Remember to eat your desert first as you may die before your food arrives.
Tagwatts1 is offline
post #4 of 7 (permalink) Old 12-21-2014, 09:51 AM
Honored Member
harrysin's Avatar
First Name: Harry
As has been said, it is a bit like comparing apples with pears. They each have their abilities but whereas the Dremel cannot do all that a trim router can, a trim router can, and much more. The ideal situation of course is to have both and I'm fortunate in that I do!
Harry
harrysin is offline
post #5 of 7 (permalink) Old 12-21-2014, 11:53 PM
MAFoElffen's Avatar
I too have both. Many trim class routers. A couble dremls with a plugne and fixed router based.
*** Ask what would be better for inlays... That was the question ask by OP.
A Dremel makes a good rotary tool for quick detail work... but I've never thought of my Dremels as a tool that removes much material at a time, nor something I would use for extended periods of time. The bearings get hot when trying to route for very long. It doesn't take a load very well, so you have to make very shallow depth of cuts. The adjustments for depth of cuts are rudimentary and not made for precison (more for abut this much kinds of adjustments). The router type bits for a Dremel ar every limited.
A Trim router has more power and is steadier. Being steadier, I find it more consistent and easier to get an accurate cut.
I use both, but each has it's pro's and con's.
MAFoElffen is offline
post #6 of 7 (permalink) Old 12-22-2014, 09:29 AM
Honored Member
harrysin's Avatar
First Name: Harry
Mike, just to clarify, a trim router in my usual humble opinion is better than a Dremel in a plunge base for every operation. But out of the plunge base the Dremel can do lots of things better than a trim router. In other words they both have their uses.
Harry
harrysin is offline
post #7 of 7 (permalink) Old 12-22-2014, 11:49 AM
MAFoElffen's Avatar
I have both Dremel router bases. I had the old Dremel fixed router base. Then when I read your review on their plunge base, it convinced me to try that one.
As you say with you... I have a good eye and steady hand. There is a lot of things that I do freehand. But from teaching and working with others, I know other's are not as steady.. A Dremel gives no concession to be using bushing guides and patterns. Agreed that most we do with a Dremel is a freehand affair.
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 09:51 AM
DW625 type 2 DeWalt Plunge router base plate screws newcal Guide Bushings and Templates 11 07-04-2017 03:53 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Plunge vs Fixed Base kstern New Member Introductions 20 03-02-2013 08:21 PM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
