Festool OF 1010 under base dust swiveling shroud - Router Forums
 2Likes
  • 2 Post By RainMan 2.0
post #1 of 5 (permalink) Old 01-05-2015, 09:13 PM Thread Starter
First Name: Peter
Default Festool OF 1010 under base dust swiveling shroud
Hi
May I ask if anyone has used the above router with the under base rotating dust shroud please? How much dust does it collect when edge routing ?
Peteroo is offline
post #2 of 5 (permalink) Old 01-05-2015, 09:29 PM
RainMan 2.0's Avatar
I was really impressed as it was pretty much the majority of it when I tried . I wear a mask regardless but I couldn't see any dust on the floor . My only negative was when I tried to go around a corner and it got hooked on the edge . No biggy really .
I use a general international dust extraction unit connected to Festools overpriced pipe , but TimberTaylor found a great alternative from Bosch I believe for the pipe .
Btw mine is the Festool 1400 but I think there quite simular
timbertailor and Cochese like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 5 (permalink) Old 01-06-2015, 06:32 PM
First Name: Larry
Like RainMan I have the OF1400 and it does an excellent job of collecting the dust. It is harder to see with the dust extraction on tho.
Knot working is offline
post #4 of 5 (permalink) Old 04-16-2015, 09:52 AM
First Name: Brad
It does slow you down a little around the corners but its ability to capture sawdust is well worth the extra effort. I too own the bigger brother but they operate the same way.
You can get a cheaper hose from Home Depot. Part number# VAC0005, as Rick alluded to. This allows you to hook it up to your shop vac or DC system.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
post #5 of 5 (permalink) Old 01-18-2016, 10:44 AM
First Name: Chris
I've had the of1010 a few years now and used with my midi vac it gets pretty much 99 to 100% of the dust when using the swiveling chip catcher. I'll be getting the of1400 this week hopefully the dust catcher on that will be just as good.
Sent from my MotoE2(4G-LTE) using Tapatalk
londonjoiner is offline
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 06:58 AM
Dust collection base for pc 690 series routers rstermer Portable Routing 6 06-12-2008 08:42 AM
Anyone using a plunge PC 890 base with dust pickup? paulcomi Portable Routing 16 07-04-2007 01:57 PM
