which dust hood kit bosch MRC23EVSK - Router Forums
post #1 of 3 (permalink) Old 01-28-2015, 12:28 AM Thread Starter
First Name: Peter
Default which dust hood kit bosch MRC23EVSK
Hi
does anyone know which dust hood kit is applicable for the above for under base dust extraction for both fixed and plunge bases and above base for fixed base please?
Peteroo is offline
post #2 of 3 (permalink) Old 01-28-2015, 12:41 AM
Originally Posted by Peteroo View Post
Hi
RA1177AT Dust Extraction Hood Kit | Bosch Power Tools
post #3 of 3 (permalink) Old 02-01-2015, 11:20 AM
First Name: Erich Weiss
That is the same kit I have for my MRC3EVSK. It works well. I have an insert plate from Rockler and with the dust extraction hood installed, I cannot remove the plate from the table unless I remove the dust extraction hood. Not really a big deal as I change the bit by removing the motor from the fixed base, but something to consider. It can be a tight fit depending on the size of your router table.
houdini28 is offline
New to forum JHinNJ New Member Introductions 10 01-01-2015 11:56 AM
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 07:58 AM
Lathe Dust Hood Origami jjciesla Woodturning and Lathes 14 12-28-2008 10:07 PM
Bosch router dust attachments Qstick Tools and Woodworking 1 07-08-2007 06:10 PM
Found: Wanted Bosch RA1173 Dust Extraction Hood -Sam- Woodworking Classifieds 10 11-01-2005 11:43 PM
