opinions on this router - Router Forums
post #1 of 10 (permalink) Old 02-16-2015, 01:00 PM Thread Starter
First Name: Bob
Default opinions on this router
If anyone recognizes this router (I'm in Canada) .... any opinions.
I don't have the brand-name or model.
The seller wants $25 for it.
Should I buy it??
Thanks,
Bob
rsauve999 is offline
post #2 of 10 (permalink) Old 02-16-2015, 02:06 PM
Bob, is is just the table or does it also have a motor. Can't tell from the picture. One observation either way ids that the table is very small and the opening on the fence for the bit is small so it will be limited in what it can do. It also appears that you will need to make a stand for it to sit on.
post #3 of 10 (permalink) Old 02-16-2015, 02:43 PM
It looks like it's plastic? If so, run away...
DaninVan is offline
post #4 of 10 (permalink) Old 02-16-2015, 03:00 PM
Semipro's Avatar
First Name: John_*
Not me not worth driving over to pick it up
Semipro is online now
post #5 of 10 (permalink) Old 02-16-2015, 03:12 PM
boogalee's Avatar
First Name: Al
It looks like the table for a Dremel rotary tool.
Al B
boogalee is offline
post #6 of 10 (permalink) Old 02-16-2015, 07:13 PM
RainMan 2.0's Avatar
Good call Al
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 10 (permalink) Old 02-16-2015, 07:14 PM
First Name: Earl
Looked that up, and i think you're right Al. http://www.amazon.com/Dremel-231-Sha...l+router+table
The table can be had for $30 new here in the USA, no idea about north of the border (and southeast of Alaska!!). If it's table only, and something you could use, and brand new never been out of the box--maybe worth $25 on the high side. Now...if it has a Dremel tool attached, it may be a steal (if the tool works, it's something you could use)
I don't know that i will need to go smaller than my Bosch Colt--but that's just me. Obviously, it works for some people 'cuz Dremel sells enough to keep making them.
earl
greenacres2 is offline
post #8 of 10 (permalink) Old 02-17-2015, 09:07 AM
It is a Dremel Table. Great if you are into models and such. Limited selection of router bits to use with it. They need to be 1/8".
pretender74 is offline
post #9 of 10 (permalink) Old 02-18-2015, 12:34 PM
Country: Mexico
First Name: Joseph Anthony
Arrow
I have one and works fine for little pieces or work. Even it is plastic, is strong enough for its ligh work.
RÖENTGEEP is offline
post #10 of 10 (permalink) Old 02-18-2015, 03:35 PM Thread Starter
First Name: Bob
Thanks for all your replies. Yes, it's for a Dremel & is plastic.
Another router table is included - but I don't have photos.
Build an economy table top and install a mounting plate Mike Table-mounted Routing 93 01-15-2016 11:52 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Freud 2.25 HP router combo Opinions Cal67 General Routing 38 03-30-2009 01:41 AM
Router opinions Rezy81 General Routing 4 03-19-2009 07:26 AM
