First dado with router - Router Forums
 10Likes
post #1 of 13 (permalink) Old 03-24-2015, 07:01 PM Thread Starter
Default First dado with router
Did my first dado with the router, which will be how I do it from now on probably. Sure like not screwing around with taking dado blades on and off the table saw. Plus it was a perfect 3/4.
I need to remake the T jig I made. I never thought about doing plywood and doing both sides of the shelve at the same time. No marking the wood, and both exact. But my jig was not long enough to do 20" across.
Just a practice plywood shelf for basement. I was impressed with how the bit did 1/4 depth on first pass. Can I expect this on hard wood too?
Zerk is offline
post #2 of 13 (permalink) Old 03-24-2015, 09:41 PM
First Name: Clay
Good job I guess. Did not see a pic of a dado or your T jig whatever that is.
hoangtrong001cho likes this.
fire65 is offline
post #3 of 13 (permalink) Old 03-24-2015, 10:30 PM Thread Starter
I think I saw the jig here. Just two pieces of plywood screwed togeth to make a T. Long part sits on piece, is guide for router, other pieces butts against piece, holding it at 90. Run bit through the piece, so you can line up where your bit will cut.
I can take pic tomorrow. I have seen more complicated ones, but this is quick and dirty and can make one for another size dado fast.
Zerk is offline
post #4 of 13 (permalink) Old 03-24-2015, 10:43 PM Thread Starter
Nothing fancy, but for a beginner, it worked good.
How to Build a Router Jig for Perfect Dadoes | Startwoodworking.com
Zerk is offline
post #5 of 13 (permalink) Old 03-25-2015, 01:11 AM
Phil P's Avatar
First Name: Phil
Like this one, Zerk?
Works for me.
Regards
Phil
Name:	Router T-Square.jpg
Phil P is offline
post #6 of 13 (permalink) Old 03-25-2015, 07:12 AM Thread Starter
Very similar
Zerk is offline
post #7 of 13 (permalink) Old 03-25-2015, 03:52 PM
Phil P's Avatar
First Name: Phil
Quick and dirty - ready in 5 minutes
Phil P is offline
post #8 of 13 (permalink) Old 01-07-2016, 06:08 PM
First Name: Dustin
This is such a good idea! I'll have to keep this in mind for my next project
Sent from my iPhone using Tapatalk
hunterguy86 is offline
post #9 of 13 (permalink) Old 01-07-2016, 06:14 PM
Pretty neat doing something like that for the first time. I don't use a shop made jig, but have something called a Dado Wiz, which is a metal device that gives you an exact fit groove, dado or rabbit, exactly where you want it.
DesertRatTom is online now
post #10 of 13 (permalink) Old 01-07-2016, 07:06 PM
Nickp's Avatar
First Name: Nick
You might try your jig with a 1/2" bit and take two passes to size for ply...it's a bit less than what a 3/4" bit will cut and will make it more exact fit.
Several jig designs are available for precise dado/groove cutting for different size wood...
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
