Profile cutting - Router Forums
post #1 of 6 (permalink) Old 04-05-2015, 11:27 PM Thread Starter
Country: South Africa
First Name: Johann
Send a message via Skype™ to johannmendelsohn
Default Profile cutting
Need to cut a length of timber into a profile to
match, but not to join two edges on opposite sides of an antique table. The base stock dimension about 32x38mm. As I do not have a spindle cutter and my router bits are too small to cut a cove this size, I please need som advice! The the outside curve I could plane and sand but the inside curve stays a problem. Any ideas? Thank you.
johannmendelsohn is offline
post #2 of 6 (permalink) Old 04-06-2015, 01:20 AM
old55's Avatar
First Name: Ross
Johann I'm sure someone will be along to give you a helping hand.
Ross,
old55 is offline
post #3 of 6 (permalink) Old 04-06-2015, 06:23 AM
First Name: Denis
Hi Johann
Search Google on "Cove cutting on a circular saw".
Denis Lock - "Routing with Denis"
denis lock is offline
post #4 of 6 (permalink) Old 04-06-2015, 07:24 AM
waynecochran's Avatar
First Name: Wayne
Go to youtube and search for Matthew Cremona. He has some videos on making a large 's' shape profile.
waynecochran is offline
post #5 of 6 (permalink) Old 04-06-2015, 09:25 AM
First Name: Gary
Johann, The inside radius could be quickly done with a #8 wooden rounding plane, which has a 1" wide blade and cuts a 1" radius.
gmercer_48083 is offline
post #6 of 6 (permalink) Old 04-06-2015, 12:18 PM Thread Starter
First Name: Johann
Thank you to all! I tried the cove cutting on the table saw and it worked. The cove calculator on Fine Woodworking's website did cut out a lot of trial and error. The #8 round plane sounds good but will be a bit difficult to obtain in my area. Thanks again!
Need Advice on Cutting this Profile mikedpp Guide Bushings and Templates 12 01-27-2014 07:47 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 02:11 PM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 11:49 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 02:29 PM
