Router Life Expectancy - Router Forums
 19Likes
post #1 of 42 (permalink) Old 06-22-2015, 06:07 PM Thread Starter
Marco's Avatar
Default Router Life Expectancy
In a production environment flush trimming 2000 feet of 19/32 osb per week, what do you think the life of the router should be? This assuming a half sharp bit is being used by a half caring worker.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #2 of 42 (permalink) Old 06-22-2015, 06:17 PM
RainMan 2.0's Avatar
So put new bearings in it and carry on
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 42 (permalink) Old 06-22-2015, 07:10 PM Thread Starter
Marco's Avatar
This is after the bearings, switch, plate,everything that can be busted has been replaced, repaired and rigged. Just before of the company bugler jumps out, plays taps and slams it in the dumpster,
billyjim likes this.
Marco is offline
post #4 of 42 (permalink) Old 06-22-2015, 07:11 PM
I would have a couple of back-up routers available,just in case. That OSB is loaded with glue and hard on bits. Not sure about routers tho. When I edge trimmed OSB it was really rough. Quite unacceptable for my taste. How thick of panels?
Herb Stoops is online now
post #5 of 42 (permalink) Old 06-22-2015, 07:55 PM Thread Starter
Marco's Avatar
Herb the panels are 19/32 thick with the overhang to be cut off ranging from 3 to 16 inches and the length of one cut/job ranging from 52 to 92 feet. It beats the wires out of a router. We are currently using Porter Cables 3.25hp router.
Marco is offline
post #6 of 42 (permalink) Old 06-22-2015, 11:09 PM
Is there a reason you don't use a skilsaw? They cut OSB very well.
post #7 of 42 (permalink) Old 06-23-2015, 12:34 AM
Jim, are you using dust collection with the router? This would make a huge difference since you are keeping the bulk of the dust out of the motor. That will greatly extend the components life. Is this a 7518 or the older series?
I think a Stacc-Vac would be a great value for your needs. You can see the plastic shield on my 7518; this photo was taken at the International Sawdust Saturday event when we were comparison testing different brands of bits. The combination of the larger base with the extra handle provides better control and the vacuum port captures most of the dust; the plastic shield helps contain the dust so your motor is sucking clean air. The bit guard/brushes do a good job of capturing dust that would normally hit the floor. You can learn more about the Stacc-Vac here: Betterley Industries
Name:	STACC-VAC 7519 Sam SS EM.jpg
post #8 of 42 (permalink) Old 06-23-2015, 01:07 AM
from experience...
Bosch out lasts PC by a wide margin but the half sharp/caring factor has been removed...
all of my PC's got bugled...
Bosch is still at it...
and MDF not spoken here...
timbertailor likes this.
post #9 of 42 (permalink) Old 06-23-2015, 01:23 AM
I was kind of wondering about the router vs circ. saw thing myself(?).
Cutting 1/3 of a mile of 1/2" OSB per week is asking a lot of a builders saw, never mind a router.
To clarify, the sawblade is removing maybe 1/8" of material or less if it's just facing up an edge.
Probably not a huge amount of heat buildup if the the blade's kept really clean and sharp.
DaninVan is offline
post #10 of 42 (permalink) Old 06-23-2015, 01:48 AM
how do we flush trim w/ a CS???
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
