7610 Type 2 - "play" in shaft - Router Forums
post #1 of 4 (permalink) Old 08-07-2015, 01:08 PM Thread Starter
Default 7610 Type 2 - "play" in shaft
(I may have put this in a forum where I wasn't supposed ask questions. I post it here too. Thanks.)
This appears to be a well made tool, but the play in the shaft is so bad, I can't use it. The play effects the depth-adjustment, not an "out of round" type problem. Do you think this is just bearings or is there more to the problem than that? I'd like to save it if I can.
Chesapeake Bob... New Member here.
Chesapeake Bob is offline
post #2 of 4 (permalink) Old 08-07-2015, 01:29 PM
Nickp's Avatar
First Name: Nick
Check out Black and Decker 7610 Parts List and Diagram - Type 2 : eReplacementParts.com
Looks like there is a thrust washer on the opposite end of the spindle (part 7)...maybe worn...? That's a quick check...and even though it might be obsolete, you could fabricate out of appropriate material.
Bearing plate (part 31) might also be loose or worn...
...and, of course, there's always the bearing which appears available.
Nick
Nickp is offline
post #3 of 4 (permalink) Old 08-07-2015, 06:06 PM
As far as I know, there isn't a machine manufacturer anywhere that makes their own bearings so that is always the one of the least of your worries. I replaced the bearings in 2 PC sanders last year, a ROS and a 1/4 sheet pad type. Different bearings but both were easy to find and relatively cheap.
post #4 of 4 (permalink) Old 08-08-2015, 08:34 AM
First Name: Gary
Most certainly the bearings. usually the bearings get noisy as time goes by, but it is a suttel increase in sound. Learn to listen for this and you will catch it before it locks up and ruins the housing it's pressed into. Use a small bearing separator type puller to remove the bearings. replace the bearings by driving them on with a socket against the inner race of the bearing. Also check the commutators for damage caused by bad bearings. also replace the brushes while your at it.
gmercer_48083 is offline
7610 Type 2 - "play" in shaft Chesapeake Bob Black & Decker 4 08-07-2015 03:54 PM
longer router shaft philr Table-mounted Routing 15 12-05-2013 05:35 PM
Repairing Older Craftsman Shaft Locks MEBCWD Woodworking Articles 0 03-08-2012 07:55 PM
Type 2 vs Type 3 Dewalt DW625 jschaben General Routing 2 10-17-2009 04:43 PM
Machining flats on band saw shaft Kristin D Tools and Woodworking 2 12-18-2007 12:34 PM
