Bosch Colt Cutting 3/4" Plywood - Router Forums
 12Likes
post #1 of 12 (permalink) Old 08-17-2015, 10:03 AM Thread Starter
First Name: David
Question Bosch Colt Cutting 3/4" Plywood
Is the Colt up to cutting 6" - 15" circles out of 3/4" cabinet-grade plywood?
harpone is offline
post #2 of 12 (permalink) Old 08-17-2015, 11:14 AM
It will but a bigger router would be better suited. You are going to be working that one pretty hard. Most of the members here would suggest that you cut close to the size circle you want on a bandsaw or with a jigsaw first.
The other issue you will have is starting the circle (I`m assuming you mean the disc and not the hole). This is a job for a plunge router to do it cleanly and safely unless you precut and use a template to guide you around the disc. If you want to cut the circle out with a router the most depth of cut you should take per pass is a quarter inch since you can only use a quarter inch bit.
How were you thinking of doing it Dave?
harpone likes this.
post #3 of 12 (permalink) Old 08-18-2015, 10:15 PM
JFPNCM's Avatar
First Name: Jon
I've used that Bosch to route out circles up to 17" in diameter in 2" cedar using the Rockler circle jig. I took very small cuts, 1/8" or less, an up cut spiral bit and moved the router slowly. No issues, but on the next round I'm moving up to bigger router.
The band saw, jigsaw is an excellent suggestion as well and then finish the edge with the router.
harpone likes this.
Jon
JFPNCM is offline
post #4 of 12 (permalink) Old 08-19-2015, 12:25 AM
Shouldn't be a problem David. The PRO12 dust collection adapter works well.
Name:	Colt plunge.jpg
harpone likes this.
post #5 of 12 (permalink) Old 08-19-2015, 03:36 AM
First Name: 4D
It'll do it. Just take small passes, replace bits often, and the best advice already given is to pre-cut using a band saw. Stay within 1/16" or so of the line freehand, or use a simple jig if you can affix the center point to spin the piece through the blade.
Colts are often used on small CNCs. I've replaced brushes after using one for a couple of years and run it for another two years before the bearings went. Good little work horse. Plywood varies though, and most flavors are hard on bits.
4D
harpone likes this.
4DThinker is offline
post #6 of 12 (permalink) Old 08-19-2015, 08:15 AM
@Mike ..
don'ja you ever use your stuff ???...
all it always looks so virgin...
old55, RainMan 2.0 and hawkeye10 like this.
post #7 of 12 (permalink) Old 08-19-2015, 10:19 AM
Stick, I'll let you in on a secret: I take the photos before I use the tools for future reference. I do my best to keep them clean after use. I have posted many times that I use compressed air after each use to blow the dust off and out of my tools. I also use dust collection when ever possible. It really helps that they don't travel to job sites.
Here is an example: these photos were taken of the Sjobergs Smart Vise before any work was done with it. The same is true of the Portamate 3-1/4 hp router motor for use in router lifts.
Wait, did Mike say router lift??? The plot thickens! Tune in next week, same bat time... same bat channel!
Name:	Smart vise 1.JPG
Name:	Smart vise 2.JPG
Name:	Portamate Router 1.JPG
Name:	Portamate Router 2.JPG
rcp612 likes this.
post #8 of 12 (permalink) Old 08-24-2015, 09:15 AM Thread Starter
First Name: David
Default Undecided
Chuck -
I was thinking of using Jon's method, circle jig & router. After reading all the replies I wonder whether the bandsaw/router method might be easier. I have made several circles on my small bandsaw and was looking for a better, faster way. I have never routed plywood; what kind of edge finish should I expect?
Dave
harpone is offline
post #9 of 12 (permalink) Old 08-24-2015, 12:57 PM
David the problem using a circle jig without a plunge router is starting the hole. The jigs are meant to be used with a plunge. Many of the members here will tell you that if you only have one router it should be a plunge because it can do anything a fixed base can but the opposite is not true. In your case you should be considering using a template type jig with either template guides or a pattern bit so that you can advance the bit into the cut safely.
Finish is based on a few variables the most important of which is the sharpness of the bit. You can get straight bits that have a shear cut angle on them or a spiral bit. A bit with spiral or shear angle will leave one edge smooth and the other rough. A compression type spiral will leave both edges smooth but the bits are quite a bit more costly. All panel boards (ply, mdf, etc) are harder on bits than wood is.
As mentioned, you should only be routing 1/8 to 1/4" if you are using the bit for cutout purposes so this isn't going to be any faster than the bandsaw method and much harder on the router and bits and router bits are more costly per inch of cut than bandsaw blades are.
post #10 of 12 (permalink) Old 08-29-2015, 10:14 PM
I agree with Chuck... cutting plywood or MDF or most any of the man made stuff is tough on tooling. I have done a few jobs where I went all the way through 3/4 ply but was also using 1/2" compression spiral or chip breaker bits.
My inclination in taking on that job with a Colt would be to use a 1/4" spiral bit and cut the circle approximately 1/4" deep. Then use a band or jig saw to cut the circle staying within the 1/4" wide router cut groove. Then use a flush trim bit on the router table to finish the cut.
Takes a bit longer but much easier on the equipment. JMHO
John Schaben
jschaben is offline
Bosch Colt on a Full Size Table Question JHZR2 Table-mounted Routing 5 12-05-2013 02:32 AM
bosch colt plunge base meddoc General Routing 7 07-24-2012 06:33 PM
Bosch Laminate Routers - old accessories with new (Colt) zzdodge Portable Routing 2 08-12-2009 09:34 AM
Cutting Plywood Lengthwise or Widthwise mshaf23783 Tools and Woodworking 1 06-27-2007 08:26 AM
cutting plywood on a 45 with a router joe carter Tools and Woodworking 2 10-24-2005 07:00 AM
