I need find any router edge for my base router - Router Forums
 3Likes
post #1 of 12 (permalink) Old 10-04-2015, 05:25 AM Thread Starter
Country: Italy
Default I need find any router edge for my base router
hi... I have a base router model dremel advanced 963-01 out production.
I need of edge for this base, but i don't know whitch can fit fine...
I think of fit any brand possible and also mod it if similar
thanks
goldwood is offline
post #2 of 12 (permalink) Old 10-04-2015, 05:32 AM
thanks
you looking for this???...
about 25$ USD....
near as I can tell the guide isn't sold separately...
https://www.dremel.com/en-us/Tools/P...1#.VhDxd0ZD_4Y
post #3 of 12 (permalink) Old 10-04-2015, 05:38 AM Thread Starter
Country: Italy
no I locking for only edge guide not base, this base is advanced version, and i need use for semi-professional works... I need of fit on a edge guide only.
Also all compatible edge, the problem is I not know the distance among 2 rods. My hole supports rods distance 8,5 centimeters (3,346")
goldwood is offline
post #4 of 12 (permalink) Old 10-04-2015, 05:52 AM
use the picture as a reference and make one...
post #5 of 12 (permalink) Old 10-04-2015, 06:05 AM Thread Starter
Country: Italy
you mean I would make do it yourself ?
goldwood is offline
post #6 of 12 (permalink) Old 10-04-2015, 06:08 AM
correct....
post #7 of 12 (permalink) Old 10-04-2015, 07:24 AM
Have you tried calling Dremel about this? This PDF file shows all the parts for the edge guide, circle guide, rods and fasteners for the new plunge base. By looking at the pictures you should be able to build the parts if they are not available.
post #8 of 12 (permalink) Old 10-04-2015, 08:06 AM Thread Starter
Country: Italy
this is base not same 963-01, check better... I need of fit on my base a more advanced edge guide . I want fit in a industrial or better built of dremel brand..
And the edge guide of model 335-01 it have a guide that cannot work up to center . If i can know the measure distance among rods of edge guide on commerce, i can attached it on my.. I hope to be more clear..
goldwood is offline
post #9 of 12 (permalink) Old 10-04-2015, 08:08 AM
Nickp's Avatar
First Name: Nick
Goldwood...see my reply in your introduction...I posted an answer in the wrong thread...
rross likes this.
Nick
Nickp is offline
post #10 of 12 (permalink) Old 10-04-2015, 08:16 AM
Nickp's Avatar
First Name: Nick
You can add a sub base that will hold any edge guide...see crude picture attached...
The rods from the edge guide would be sandwiched between the two bases...the New base could be notched for any distance of the rods.
ksidwy likes this.
Nick
Nickp is offline
Buncha Questions JohnnyRelentless Table-mounted Routing 4 06-21-2014 08:07 PM
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 10:00 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 02:40 PM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
