Trimming with Bosch Colt vs Edge Sanding - Router Forums
 9Likes
post #1 of 12 (permalink) Old 10-04-2015, 01:43 PM Thread Starter
First Name: David
Default Trimming with Bosch Colt vs Edge Sanding
I am making a large Noah's ark puzzle using old oak I have planed to slightly less than .75 inch. This involves 8 ellipses which I cut on a bandsaw leaving a 1/16"-1/8" border. On previous medium ark puzzles (cherry, poplar, pine) I sanded (Ridgid Oscilating Edge Belt/Spindle Sander) to the pattern line. Is this something I could do as effectively (and faster) with the little Bosch router?
harpone is offline
post #2 of 12 (permalink) Old 10-04-2015, 02:14 PM
In my mind the ideal way to do that would be by using a template stacked on the the piece you want to cut and use a flush trim bit on a router table. I think that would be the fastest, easiest, and most accurate.
harpone likes this.
post #3 of 12 (permalink) Old 10-04-2015, 04:08 PM
DonkeyHody's Avatar
First Name: Andy
If you are talking about using a straight bit on the router to try to carve the pieces to a marked line, NO, don't try it. It's a guaranteed way to ruin a workpiece. You'll be routing along just fine, thinking how easy this is, and then the bit will grab an end grain and split off a chunk or dig into the wood way past the line. As Chuck said, you could use double-sided tape to attach a template and use a pattern bit to shape the edge, but even then, you'd need to already be within a 16th or so from the line to avoid grabbing problems with the small-diameter bit that the Colt will spin. I think your spindle sander is the way to go.
Gaffboat and harpone like this.
DonkeyHody is offline
post #4 of 12 (permalink) Old 10-04-2015, 09:17 PM Thread Starter
First Name: David
Thanks. I will continue to go the Ridgid sander route.
harpone is offline
post #5 of 12 (permalink) Old 10-04-2015, 09:22 PM Thread Starter
First Name: David
Thanks. Because I am only intending to make one of the large ark puzzles it is too late too consider a template. I will just go ahead an sand to the pattern line as Andy suggested.
harpone is offline
post #6 of 12 (permalink) Old 10-04-2015, 09:47 PM
Good choice.
Shop guy and harpone like this.
post #7 of 12 (permalink) Old 10-05-2015, 10:10 AM
First Name: 4D
You can stick a flush trim bit into a handheld router, and use it to follow a template to smooth out the bandsawn piece. You need a template of course. I like 1/4" hardboard. They make flush trim bits with the bearing on top (close to the router plate), and the little bosch should have no trouble trimming off 1/16" or so. Its small base plate makes it hard to keep square on an edge. Remedy that by making a temporary, larger base plate for it. With any wood you may have tearout when you get to grain running into the board. In those areas I'll flip the board over, swap the template to the other side, so all cuts have the grain coming OUT of the wood.
patlaw and harpone like this.
4DThinker is offline
post #8 of 12 (permalink) Old 05-31-2016, 12:06 AM
On vacation
Nice post, Thanks for sharing it with us.
harpone likes this.
cynthiamyra is offline
post #9 of 12 (permalink) Old 07-22-2016, 06:05 AM
Country: Germany
I am curious to see how the finish Noah's ark puzzle look like.
Beer because no great story ever started with someone eating a salad __ http://7routertables.com/
tchouken is offline
post #10 of 12 (permalink) Old 07-25-2016, 01:06 PM Thread Starter
First Name: David
Default Noah's Ark Puzzle
I have everything cut out and fitted. I have yet to glue the cabin and poly/paint......got started on a couple other things and am waiting for cooler weather to do the finishing touches on the ark, noah and the animals. I will try to remember to post a picture of the finished product.
QUOTE=tchouken;1269274]I am curious to see how the finish Noah's ark puzzle look like.[/QUOTE]
harpone is offline
Bosch Colt Plunge Base Ben in Cypress Texas Portable Routing 5 05-18-2013 10:10 PM
Bosch Colt trim router echdal General Routing 17 02-28-2012 07:05 PM
Trend T4EK versus Bosch Colt thistlefly Portable Routing 15 06-09-2010 02:38 PM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 07:12 PM
Trimming mitered hardwood edging Drew Eckhardt General Routing 5 10-11-2008 07:59 PM
