Clarity on Model numbers Makita Trim RT0700 - Router Forums
 1Likes
post #1 of 11 (permalink) Old 11-24-2015, 09:44 AM Thread Starter
Country: South Africa
First Name: Reinhardt
Default Clarity on Model numbers Makita Trim RT0700
Hi All,
I'm about to order the Makita Trim Router but now notice that there is a RT0701 vs the one I know RT0700.
Is this an improved model or a "USA Spec" machine at 115V?
Please advise before i buy.
RainHard is offline
post #2 of 11 (permalink) Old 11-24-2015, 12:26 PM
Are you buying it online, Reinhardt? I think you're absolutely right in getting a definitive answer before ordering it...unfortunately I can't answer the question. Doesn't Makita have a distributor in SA?
DaninVan is offline
post #3 of 11 (permalink) Old 11-24-2015, 01:13 PM
Originally Posted by RainHard View Post
Hi All,
seems the 700 is on the way out...
Makita - Search Results
Makita USA - Tool Details - RT0701C
post #4 of 11 (permalink) Old 11-24-2015, 01:55 PM
That's my understanding too, the 701 is a replacement for the 700. Go with the 701, there will be parts available for a longer period of time.
gjackson52 likes this.
post #5 of 11 (permalink) Old 11-25-2015, 05:53 AM Thread Starter
Downloaded the Parts list - identical
Downloaded the Instruction manual - identical (infact same for the 2 units)
I give up - looks like the same machine!
Perhaps and accessory change?
RainHard is offline
post #6 of 11 (permalink) Old 11-25-2015, 08:26 AM
Garyk's Avatar
First Name: Gary
Don't know about the router but with their cordless drills the difference (as explained to me by HD) is that one device is for general homeowner use and the other is commercial use. I know for sure that they have a slightly different # between their brushed motor and the brush less. It would make sense for a commercial shop to buy brush less.
Garyk is offline
post #7 of 11 (permalink) Old 11-25-2015, 08:57 AM
vchiarelli's Avatar
First Name: Vince
Can't answer your questions regarding the differences, but as @Stick486 and others have said - the xxx700 was discontinued and replaced by the 701.
Here's a link to a forum post from early 2014 asking the same question:
http://www.routerforums.com/general-...tml#post373578
vchiarelli is offline
post #8 of 11 (permalink) Old 11-25-2015, 09:00 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
`I have two of them, compact variable speed motor and you won't be unhappy, I wish I cold buy them with all the attachments and different bases, this is a lightweight router so very good for small jobs. N
neville9999 is offline
post #9 of 11 (permalink) Old 11-25-2015, 09:28 AM
Honored Member
First Name: pat
Quillman is offline
post #10 of 11 (permalink) Old 11-25-2015, 10:17 AM
First Name: 4D
That Makita is exactly like the Performax trim router Menards sells. I believe MLCS also sells that model as the Rocky 30 trim router. I bought 5 of the Performax ones for a CNC tool changer project. They were $39 on sale. I also bought a couple of bases made for Makita (tilt and offset) which fit the Performax perfectly.
http://www.menards.com/main/tools-ha...55916640840892
Rocky 30 Trim Router
4D
4DThinker is offline
Makita RT0700 Router Template Guides Jakexp Guide Bushings and Templates 12 11-16-2014 07:51 PM
Circular Saw Makita 8 1/4" Circular Saw (Model 5008NB) Marcel M Makita Manuals 0 05-14-2013 03:15 PM
New Makita trim router kit with plunge base! Doctor Atomo Portable Routing 9 04-19-2012 03:09 PM
