Jointing Touch-up with Bosch Colt - Router Forums
 9Likes
  • 9 Post By Stick486
post #1 of 2 (permalink) Old 02-17-2016, 08:49 PM Thread Starter
First Name: David
Default Jointing Touch-up with Bosch Colt
I jointed my small supply of walnut boards 1/4" to 5/8" thick. When I go to edge glue some of the stock, I am pretty sure I will find some edges not as square as I would like. Can I clamp a straight edge to the stock and route anything that needs a little trim? I have seen a recommendation involving an aluminum angle attached to a board and another that uses a steel straight edge. As usual I am looking for the most economical solution. BTW my scroll saw has a 20" limit so I don't really need anything longer than 24"
harpone is offline
post #2 of 2 (permalink) Old 02-17-2016, 09:07 PM
speed square clamped to the board as a guide and a trim bit in your router...
BernieW, JFPNCM, billyjim and 6 others like this.
Bosch Colt on a Full Size Table Question JHZR2 Table-mounted Routing 5 12-05-2013 02:32 AM
New Bosch Colt Owner JHZR2 New Member Introductions 5 12-04-2013 12:01 PM
Bosch Laminate Routers - old accessories with new (Colt) zzdodge Portable Routing 2 08-12-2009 09:34 AM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 08:12 PM
template guides for Bosch Colt RuggerJoe Guide Bushings and Templates 13 02-10-2009 09:41 AM
