Tongue and groove tearout - Router Forums
 12Likes
post #1 of 27 (permalink) Old 05-24-2016, 02:14 AM Thread Starter
Default Tongue and groove tearout
Hi
Help, I am stuck!
I am routing tongue and groove hardwood planks which are too long to go over a router table. Am using a handheld router with a single tongue and groove bit fitted with a bearing. I have an identical piece of wood for supporting the router so am moving/supporting it along a flat surface.
The finish of cut on the groove is fine, but when i cut the tongue it has a ragged finish on the edge where the cornerof the tongue has flaked/chipped. Its not the end of the world as it will be hidden, but it would be nice if it was a clean cut.
Anyone any thoughts as to what i am doing wrong?
Mrs C is offline
post #2 of 27 (permalink) Old 05-24-2016, 02:43 AM
First Name: Keith
Does this happen with all the boards, or just some of them?
It could be the direction of the grain causing the trouble. Perhaps try running the router the other direction, as in a climb cut. It may help.
BTW, welcome to our little corner of the web.
Roy Drake and Herb Stoops like this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #3 of 27 (permalink) Old 05-24-2016, 05:04 AM
Originally Posted by Mrs C View Post
Hi
Help, I am stuck!
welcome to the forum Hrs. C...
climb cutting may be the help you are looking for...
post #4 of 27 (permalink) Old 05-24-2016, 06:51 AM
have you considered splining instead of T&G???
less waste that will seriously add up w/ a lot less mess...
Shop guy, kevin887 and jj777746 like this.
post #5 of 27 (permalink) Old 05-24-2016, 07:43 AM
I now prefer using splines whenever possible. When making very fine measurements such as what you did on the bit, I find it works best to use one of those 6 inch pocket rules with a sliding clip, marked in 32nds. Need a magnifying glass to read it, but it is very accurate for things like measuring small offsets, blade height and such.
Name:	pocket rule with clip.jpg
jj777746 likes this.
post #6 of 27 (permalink) Old 05-24-2016, 07:48 AM
First Name: Richard
Welcome to the forum, Mrs C. I like Stick's idea of using splines the best. Saves material and a lot easier.
Shop guy is offline
post #7 of 27 (permalink) Old 05-24-2016, 07:59 AM
splines use up drops and what can be construed as waste...
you can still use the grove cutter to do your splines....
post #8 of 27 (permalink) Old 05-24-2016, 08:25 AM
hawkeye10's Avatar
First Name: Don
Splines would work great as others have said. To do the tongue and groove you might try doing the tongue in two passes. Taking lighter cuts helps problems a lot.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #9 of 27 (permalink) Old 05-24-2016, 08:48 AM
Welcome to the forum Mrs. C. If you clamped the two boards together tightly then that pressure should prevent the bit from tearing grain out as it finishes the first board. I also prefer to spline however. Much simpler and you'll save about 1/2" of wood for every board you are using. As pointed out that adds up over time. A spline joint is basically the same as a T & G joint, the exception being that there are two grooves and the tongue is free floating instead of attached to one of the boards.
In the case of flooring the tongue is strictly for alignment purposes so it is imperative that you work from the back side of the boards and not the face. The backs must all sit flat on the sub floor and a tongue at the wrong height will lift one of the two boards off the sub floor which will cause squeaking and possibly crack one day. Traditionally hardwood floors were installed and sanded in place to get the top flat. Modern mating methods may be accurate enough to eliminate the different heights problem but it's best not to take a chance.
Since it's only for alignment you could use hardboard or ply for tongues. I had some thin wooden T & G paneling once that perfectly fit one of the slotting cutters in my set so I used it for splines.
post #10 of 27 (permalink) Old 05-24-2016, 09:13 AM
Nickp's Avatar
First Name: Nick
Welcome, Mrs. C...
What is likely happening is the cutter, as it is exiting the cut at a high angle where the grain ends, will lift a slight amount rather than cutting it cleanly because there is no more grain support at the end of the cut. What might help is to take a light initial scoring pass so that the cutter is approaching the grain at a lower angle then "have at it"...
Red Oak is my nemesis when doing the same thing...little slivers want to break off... If they're big enough, I use them for toothpicks
Climb cutting, as has been suggested, takes care of that because the cutter is cutting down into the grain and therefore does not lift when it exits.
...nope...doing nothing wrong... but just for the heck of it, is cutter clean and sharp...? What about router speed...high enough...? Enough power in the router if you're taking it in a single pass...? Good feed speed...too fast...?
Just thinkin' of the basics...
Nick
Nickp is online now
3/8 tongue & groove assembly bit johannmendelsohn Router Bits - Types and Usage 10 09-08-2014 02:46 PM
Biscuits vs Tongue and Groove Joints CanuckGal DIY and Renovation 9 04-22-2010 04:07 AM
2x tongue and groove ? youngmj General Routing 4 02-05-2009 12:49 AM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 07:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 06:51 AM
