Long range portable router - Router Forums
 13Likes
post #1 of 18 (permalink) Old 08-07-2016, 10:35 AM Thread Starter
Default Long range portable router
Hi,
I'm seeking for a sim based portable router that can be connected to the internet (3g/4g) and supply internet connection to around 40 devices (smartphones), in a range of around 40 meters (130 feet).
I need it for a group of travelers.
Does anyone familiar with this kind of product?
Any answer will be appreciated.
Thanks in advanced.
moranamon is offline
post #2 of 18 (permalink) Old 08-07-2016, 11:15 AM
welcome to the best woodworking router forum this side of any place moranamon...
there may be some one here that may be able to help you but this forum isn't the type of router forum you are looking for...
Stick486 is offline
post #3 of 18 (permalink) Old 08-07-2016, 11:48 AM
Welcome to the forum. We have several IT professionals who also happen to love woodworking routers. Stick around. You might get the answer you want even if you aren't on the forum you thought you were on.
post #4 of 18 (permalink) Old 08-07-2016, 01:30 PM
Nuff said, but you're welcome to stay. Making sawdust gets in your blood after awhile.
TWheels and RainMan 2.0 like this.
post #5 of 18 (permalink) Old 08-08-2016, 03:29 AM Thread Starter
Thanks guys,
Waiting for someone to reply with an appropriate answer.
post #6 of 18 (permalink) Old 08-08-2016, 03:43 AM
you do woodworking moranamon???
Maybe @Nickp or @vchiarelli may be able to help you...
Stick486 is offline
post #7 of 18 (permalink) Old 08-08-2016, 07:15 AM
Nickp's Avatar
First Name: Nick
Two limiting factors...number of devices and distance...typically up to 10 devices and difficult to get to 32 meters...100mbps not likely to handle that many devices...sorry, can't help...
Nick
Nickp is offline
post #8 of 18 (permalink) Old 08-08-2016, 12:15 PM
Country: South Africa
First Name: Hentie
Good day
I stay in South Africa, so am using .co.za links. you should find something similar in your country
You want it portable, which limits the amount of oomph you can put out via the antenna, which limits the coverage distance. Most portable sim card based mifi devices firstly have got a limited range, and then secondly can only handle a limited amount of connections. I assume (correct me if I am wrong) that you want it mobile for "allways on" connection as you are traveling, or possibly to provide connectivity when you are "at rest"
That said, instead of using a single solution, I would suggest looking at a split solution = one part for the 3g/4g sim connection (basically you are only going to need a modem converting to a network point), and one that will be the dedicated access point. for power, many devices doesn't have to be on the mains - just ensure you charge a battery/powerbank, output at the correct voltage, and use that as the source.
... and then you connect both of them with a network cable to one another.
(you also get simple network hubs running of usb), a friend of mine can run his 5port dlink hub/switch from a usb - meaning it will work from a powerbank as well - this might be a great add-on if you want to extend your travel network later with an extra Access point
For a wireless access point - something like this
https://scoop.co.za/ubiquiti-unifi-e...-range-ap.html
important specs - can handle 100+ concurrent connections, 300Mb/s - so still faster than your typical 3g/4g, and long range - Range: Approx. 600 ft
more important - it uses 24v, but this is a POE device, so you either provide it with 24v through the correct connector, or you inject power over a network cable
the next component is something that can either connect via 3g/4g or take a 3g/4g connection, and provide an output to a network point - RJ45.
example - this one will use a 3g modem providing a 3g/4g connection, but I am quite sure you will get something that is integrated.
Other Computers & Networking - M1 Portable 3G WiFi Hotspot IEEE802.11b/g/n 150Mbps RJ45 USB Router for sale in China (ID:238062777)
the advantage of splitting the 2, is that you can utilize 2 components, that work very well for the specific task they do, instead of using a single device that mediocrely combines both components
also, if you do arrive anywhere where you have another source of broadband, you can possibly connect the one component (wireless access point) only.
lowracer is offline
post #9 of 18 (permalink) Old 08-08-2016, 12:34 PM
First Name: Hentie
SAWDUST?
oh, you mean "MAN GLITTER"
lowracer is offline
post #10 of 18 (permalink) Old 08-08-2016, 12:38 PM
Originally Posted by lowracer View Post
sawdust?
Oh, you mean "man glitter"
snork!
Stick486 is offline
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 12:33 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 06:40 PM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Portable Plunge Router Recommendation and Newbie Advice? riffin-rich Portable Routing 30 05-31-2011 04:41 PM
Portable Router Tables Bettercarpentry Portable Routing 10 03-07-2010 12:32 PM
