cutting bit movement - Router Forums
 6Likes
post #1 of 16 (permalink) Old 08-09-2016, 01:38 PM Thread Starter
Cabbie41's Avatar
Default cutting bit movement
Guys--
I'm stumped! I set up my Skill plunge router to do some rabbeting on MDF and poplar. The poplar was done with a top-mounted bearing bit, while the MDF used both a spiral down-bit as well as a straight flute 3/8" bit.
The collet was disassembled, cleaned thoroughly, and the tightening was "vigorous". Set the plunge depth to about 1/4" and began the cut. Within the first foot or so of cut the depth had changed to over 1/2", ruining my piece. I've now scrapped three workpieces with the same issue!!
What's happening? The only way I can get this to work is if I limit the cut depth to about 1/16", which is ridiculous and time-consuming.
Any ideas as to what's causing t he problem and how to fix it? The router is old (15-20 years) but not used very much.
Any help would be appreciated!
Cabbie41 is offline
post #2 of 16 (permalink) Old 08-09-2016, 01:53 PM
vindaloo's Avatar
First Name: Angie
Is the plunge lock not working or is it the bit coming out of the collet?
What's the size of the bit shank and the router collet?
I bought some cheap bits and they turned out to be 12mm and not 1/2", which meant they were loose even with the collet tightened as much as was possible.
bcfunburst likes this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #3 of 16 (permalink) Old 08-09-2016, 01:55 PM
First Name: Richard
My guess is the bit is bottoming out in the collet. Try taking it out. Reinstall it the pulled it out about an 1/8" and try it again on a piece of scrap.
Shop guy is offline
post #4 of 16 (permalink) Old 08-09-2016, 02:06 PM
use another/different bit on scrap and see it behaves the same way...
Stick486 is offline
post #5 of 16 (permalink) Old 08-09-2016, 02:13 PM
Honored Member
First Name: pat
Spirals, like drills, screw themselves into the work.
As such, the cutter is being pulled from the collet.
Especially one as old as yours.
New router or new collet now.
Quillman is offline
post #6 of 16 (permalink) Old 08-10-2016, 10:24 AM
Country: Mexico
First Name: Joseph Anthony
Question
Same questions and comments here.
Cheers.
Joe
RÖENTGEEP is offline
post #7 of 16 (permalink) Old 08-12-2016, 03:29 PM Thread Starter
Cabbie41's Avatar
Plunge lock is still solid. I tried lifting the bit shank out of the collet by "1/8" or so", but it's a bit of a guess as you're working blind. In any case it didn't work. The bit shanks appear OK, and they're from a set of Craftsman carbide bits and are supposed to be high quality, but I'll measure them anyway just to be sure. I can't afford a new router just now, so a fix is needed.
Thanks for any advice.
Jim
Cabbie41 is offline
post #8 of 16 (permalink) Old 08-12-2016, 04:04 PM
new collet...
I trust there is no lubricant on the bit or collet...
Stick486 is offline
post #9 of 16 (permalink) Old 08-12-2016, 04:23 PM
Jim
Some people use a rubber grommet or an o ring in the botton of the recess to prevent bottoming out. Another way to do it is to take the collet out of the router and stick the bit in it all the way and then mark the shank of the bit. Then you can see how much needs to go in. As long as you are using 100% of the collet there is no advantage to having more shank in the collet.
post #10 of 16 (permalink) Old 08-15-2016, 02:34 PM Thread Starter
Cabbie41's Avatar
Just ordered a new collet from ereplacementparts.com ($16.95+ shpg)--I hope that does it. In the interim I'm going to try using a bronze gun bore cleaning brush witih some naptha or acetone to get it good and clean.
I'll let you all know how things turn out.
Thanks for your help!
Jim
Cabbie41 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 12:08 PM
Planner bit for end grain cutting boards? Barry747 General Routing 20 08-27-2015 04:33 PM
Thread cutting bit wvcowboy Router Bits - Types and Usage 2 09-14-2011 11:04 PM
Router bit for pattern cutting MIKEKELLY Router Bits - Types and Usage 1 11-18-2010 03:16 PM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 10:09 PM
