PC 690 - Diameter of Guide Rods? - Router Forums
 16Likes
post #1 of 18 (permalink) Old 05-02-2020, 01:22 PM Thread Starter
First Name: David
Default PC 690 - Diameter of Guide Rods?
Could someone tell me the diameter of the Guide Rods used for the edge guide on a PC 690? I want to order some longer rods, than what comes with the edge guide, to build a circle cutting jig. And no, I don't have an edge guide to use as a reference. I've measured the mounting hole and I thought it was going to be 3/8" but it appears to be significantly larger than that.
Thanks in advance,
Dave.
dzempel is offline
post #2 of 18 (permalink) Old 05-02-2020, 01:32 PM
5/16''
post #3 of 18 (permalink) Old 05-02-2020, 04:32 PM
But, but, but...David said it appeared to be LARGER than 3/8". (3/8"+)
For our metric friends, 3/8" is the the same as 6/16". Stick measured his at 5/16"...somebody's mistaken.
DaninVan is online now
post #4 of 18 (permalink) Old 05-02-2020, 04:33 PM
Nickp's Avatar
First Name: Nick
"New Math"...
DaninVan and Roy Drake like this.
Nick
Nickp is online now
post #5 of 18 (permalink) Old 05-02-2020, 04:35 PM
In a recent thread, I had occasion to measure my old Craftsman guide rods at 1/4" ...ie 4/16". I didn't actually measure my Bosch guide rods but they're massive by comparison.
post #6 of 18 (permalink) Old 05-02-2020, 04:45 PM
plan ''A''...
insert rod into hole gauge...
read number next to hole...
type in the answer....
plan ''B''...
Have David insert a drill bit that fits the hole...
read size on drill bit to learn the size of the hole...
anything else I can do for ya Dan...
post #7 of 18 (permalink) Old 05-02-2020, 05:00 PM
just so ya know...
the hole size is 13/32'' or 26/64 in metric...
suspect the guide is for more than just the 690...
in metric - that would be ''one size fits all''...
Bosch has two sized rods depending on year and model...
3/8'' (6/16 metric) and 7/16'' (21/48 metric)...
older than dirt Bosch had 1/2'' rods (50/100 metric)...
post #8 of 18 (permalink) Old 05-02-2020, 05:44 PM
You beat me to it...I went out and measured my Bosch rods.... .373" (3/8" or 6/16")
They'd probably fit David's PC.
post #9 of 18 (permalink) Old 05-02-2020, 05:51 PM
the Bosch I knew...
I added 5 and 10' rods for the Bosch guide...
post #10 of 18 (permalink) Old 05-02-2020, 06:21 PM
MEBCWD's Avatar
Don't know what size but there is a Type 1 and a Type 2 PC 690 so that will probably make a difference. Do you have a caliper?
MEBCWD is offline
