Parts and Wiring for PC 7538 - Router Forums
post #1 of 6 (permalink) Old 01-04-2010, 11:42 AM Thread Starter
First Name: Daniel
Default Parts and Wiring for PC 7538
As requested, here is the parts and wiriing diagram for a PC 7538 with soft start. The wiring diagram is at the very bottom.
http://www.toolpartsdirect.com/cgi-b...rtercable/7538
or
http://images.toolpartsdirect.com/sc...e/7538.big.pdf
St. Louis, MO
Retired Welding Inspector and past Ind Arts teacher
Clouseau is offline
post #2 of 6 (permalink) Old 11-08-2014, 05:38 PM
I am considering buying a "never used" PC 7538 Plunge Router. The price is great $200 but it would not start when I tested it. It sounds like it is a bum sot start module--about $50 to fix. The guy is willing to subtract the $50 from $200.
How hard is it to replace--it looks pretty easy.
How reliable are these routers? My PC 690 seems totally reliable. Any thoughts or opinions are appreciated
Dan
danmurphy is offline
post #3 of 6 (permalink) Old 11-08-2014, 05:55 PM
Dan
"never used" ya say...
which type do you have.. there's 1 through 6....
look to the brushes 1st and change the bearings while yur at it...
read this thread....
http://www.routerforums.com/table-mo...ment-more.html
File Type: pdf Diagnosing Electric Power Tools 101.pdf (386.8 KB, 91 views)
File Type: pdf Replacing Bad, Cut, or Damaged Power Cords on Your Power Tools.pdf (79.4 KB, 89 views)
post #4 of 6 (permalink) Old 11-10-2014, 08:29 AM Thread Starter
First Name: Daniel
The module was over $70 a few years ago. Mine was $30 and ugly. I thought the switch or wire was bad. After checking those I narrowed it down to the module. The thread may still be on this site. It would be a good router for a table router, but be aware, it is a hand full if hand-held. Table mounted, you could add a heavy speed control.
Dan Coleman
St. Louis, MO
Clouseau is offline
post #5 of 6 (permalink) Old 01-02-2018, 10:43 AM
Dan
You are guessing. If it is something else like a burned out armature, you are out 200 bucks and you still don't have a router. I spent 50 years in electronics and I can't tell you how many times people would approach a repair, SURE they knew what was wrong. It is not that until you prove it. It is just a place to start, and maybe even the best possibility. That guy has a pair, selling a busted router and only subtracting the cost of the part. If he is so sure of the cause and the cost, let him fix it and sell it for 200. WALK AWAY. It would have to be a whole lot cheaper for me to buy a busted router, unless I bought it cheap, for parts. He knows you want it so he is trying to take advantage. Did he even tell you that it did not run? I bet he hoped you would not test it and then he would have refused to take it back.
Sent from my SM-G900V using Tapatalk
Mycrossover is offline
post #6 of 6 (permalink) Old 01-02-2018, 11:23 AM
Nickp's Avatar
First Name: Nick
Mycrossover...it looks like it's a very old post...he's probably taken care of it by now..
Nick
Nickp is offline
Craftsman Router wiring PETEPA General Routing 20 05-07-2014 06:29 AM
